Agency Power Mitsubishi EVO X Fuel Rails
We just did a Blog post about this on our website and I thought some of you might be interested:
Agency Power High Flow Fuel Rail EVO X 08+
Agency Power has released their new Mitsubishi EVO X fuel rail. This fuel rail is a direct replacement for the factory unit. The fuel rail is CNC machined out of 6061 aluminum, then anodized in Agency Power Red, Silver, or Black. It fits with the stock fuel pressure regulator and fittings. The fuel rail can also be set up to work with larger AN lines and aftermarket kits as well, with a simple unscrew of a piece. You can’t go wrong with the Agency Power Evo X fuel rail.
Why is this Agency Power Fuel Rail better then stock? The AP fuel rail has the largest bore currently on the market which results in better fuel flow then stock. As well, the AP rail is designed to fit larger injectors, when upgrading to a larger turbo set up or needing to upgrade your fuel system, the AP rail will accommodate your needs. While keeping stock fitment and performance when additional fuel is not needed, the fuel rail is also a great dress up piece.
All Agency Power products come with a limited lifetime warranty.
AGENCY POWER
dan@agency-power.com
www.agency-power.com
Follow us on Facebook!
Keep up with us on our BLOG!
AGENCY POWER
drinaldis
09-28-2015 01:37 PM
turbotuner20v
09-11-2015 12:02 PM
Ferrari
08-24-2015 04:35 PM
