My RX7 FD3S Re-Amemiya Twin Turbo Build
#62
finally started bolting things up
got the ignition coil pack, oil filler neck, fuel hard lines, manifold, waste gates, downpipe, etc...
then i bolted on the UIM to see what it'll sort of look like
sooooooo excited to see this!!
also i picked up an FJO Injector Driver from forum member Phrost (thanks Jay!)
so now, as far as the turbos go, the only thing thats left is to build the intercooler piping, should be getting done this weekend
#64
thanks man
the gold wrap is actually extremely functional
i started using the stuff about 1 year ago...i had wrapped my intercooler piping with it to try and get some lower intake temps on the road course
i went out for my first track day with it, and i was totally in love with the stuff after that
it brought down my intake temps by 10 degrees celcius
not to mention that after beating on the car at the track all day, i could drive my car into the pits, and full handed grip my all parts wrapped with the reflect-a-gold with no issues at all, and just sit there and hold them...the stuff is truly incredible for heat deflection
and in a rotary driven car...thats music to my ears...
after that i decided that every surface possible that needs heat protection, theres nothing better...so ye it might be a little tacky, but the benefits wayyyy out weigh the color loll
#65
Heat reduction is definitely key on the rotary. The biggest reason I went with an aftermarket nose (C-West) on my FD was not for the looks. It was because the front opening was at least twice as large as the stock one and I wanted as much air to my radiator and IC as possible. Same for my Mazdaspeed vented hood. It was to help extract air from under the hood. On a hot day without those mods, I'd do 3 laps on track and the car would start to overheat. I also put custom ducting to force air through the radiator.
Where's the best (most cost effective) place to get that gold wrap?
#66
the guys at those 2 places are great! best customer service ever and the prices are awesome
tell them VJ from Vision Autos told you to call, might get some extra discount
#67
finally got another update
the intercooler is almost done...i'll be bolting everything up tomorrow to get the car ready to go on a flat bed back to my house for final assembly on wednesday
#69
finally got my Innovative Motorsports MTX-L Wideband
I one bolted most of the car together to take it back home
almost done!!
then Roxy finally went back home!!!
got a flatbed to pick her up yesterday
i can't wait to give her a wash after 4 months!!
almost done!!
#71
and i actually sold the Volks that were on the car before
i'm going to be ordering a set of wheels ISS Forged they make the best wheels in the business by far!!
#74
actually no not yet
i got the wiring harness in
have had to put it off a bit as school and work has picked up
but tuesday i start working on her again
#75
i finally have some time to work again on friday
this is the current to-do list:
alright so heres the To-Do list
• Weld in wastegate flex bellows
• Remove A/C
• Buy Wastegate bolts
• Buy Turbo manifold/downpipe bolts
• Buy Upper intake manifold bolts
• Make ignition coil pack bracket
• Run Turbo Oil Feed Lines
• Run Turbo Oil Drain Lines
• Run Dual Oil Cooler Lines
• Bolt on Blow-Off Valve
• Plug up wiring harness
• Make Brackets for MSD/FJO boxes
• Wire in MSD
• Wire in FJO
• Run vacuum to wastegates
• Replace manifold studs
• Build manifold brace
• Replace Fuel Filter
• Add oil
• Add water
• Run grounding wires
• Remove A/C
• Wire in MSD
• Wire in FJO
• Add oil
• Add water
