VQ35 Build for More Boost!
Current Set-up:
Vehicle: 2003 Nissan 350Z Touring 6sp
Engine Code: VQ35DE
ECU: TurboXS UTEC
Audio & Electronics:
- Bel RX65 Laser/Radar Detector
- Boyo VTL300 Rear Camera
- Clifford Matrix 12.5 Security Alarm
- Defi-Link 60mm BF Series Boost Gauge
- Defi-Link 60mm BF Series Fuel Pressure Gauge
- Defi-Link Control Unit
- Defi-Link Display
- Defi-Link Indicator II
- JL Audio 500/5 Amp
- JL Audio 10W3v3 Sub
- JL Audio C5-650 Components
- JL Audio TR650Cxi Rear Speakers
- Nismo Horns
- Optima Yellow Top
- Pioneer AVIC-D3X DVD/Nav Receiver
- Pioneer GEX-P10XMT XM SAT Nav
- TurboXS DTEC Map
- TurboXS Tuner Wideband
- TurboXS UTEC w/ Map Switch
- Wicked CAS 350Z Corner Box
Brakes & Suspension:
- Aerosync CF Strut Tower Brace
- GTSpec Fender Braces
- GTSpec Front Oversized Tie Brace
- GTSpec Rear Lateral Arm
- GTSpec Rear Tie Brace
- Hotchkis Stage 1 TVS Kit
- PFC1038 Front Pads
- Posi Quiet Rear Pads
- SPL Endlinks (F&R)
- StopTech Big Brake Kit (14" 4-Pot Front, 13" 2-Pot Rear)
Engine & Drivetrain:
- AP Stainless Steel Clutch Line
- ARC Oil & Raditor Cap
- ARC V2 Oil Catch Can
- AutoTechnic CF Shroud
- Gallery Belmount Blue Dress Up Kit
- JWT Clutch & Flywheel
- JWT Oil Pan Spacer
- NGK Iridium IX 1-Step Colder Spark Plugs
- Project Kics Magnetic Oil Plug
- RC 750cc Injectors
- Stillen CF Battery & Brake Fluid Covers
- Stillen CF Engine Cover
- Stillen Oil Cooler
- UR Underdrive Crank Pulley
- Walbro 255lph Fuel Pump
Forced Induction:
- HKS SSQV BOV
- JWT 700BB Twin Turbo System
- Perrin Boost Solenoid
- Swaintech BBE Coated FMIC
Intake & Exhaust:
- APS 2.5" Test Pipes
- Cosworth Intake Plenum (Polished)
- Stillen True-Dual Cat-Back Exhaust
Interior & Exterior:
- Aerosync N-Style Front Bumper
- AUT Carbon Fiber Z Emblem Filler
- CraftSquare TC-N1 Mirrors
- Dual Guage Pod A-Pillar
- JDM Fairlady Z Emblem & Smoked Markers
- Nismo Sides
- Nismo Ti Shift ****
- '06 OEM LED Taillights
- Perrin Shorty Antenna
- Rear Strut Brace Carbon Fiber Cover
- Removed Rear Wiper
- Seibon TS-Style Carbon Fiber Hood
- Seibon TT-Style Carbon Fiber Rear Lip (Custom Painted)
- Shift Style Custom Shift Boot
- TEIN Hood Damper
- 15% Tint
- TiTek Dry CF Air Duct
- Varis CF B-Pillars
Wheels & Tires:
- ARP Wheel Studs (15mm longer)
- Ichiba Wheel Spacers (5mm Front)
- Project Kics NeoChrome R40 Racing Lugs w/ Locks
- Work Meister S1 3-Peice (19x9.5 & 19x11)
- BF Goodrich KDW Tires (255/35-19 & 285/35-19)
2012 Build:
IPP Custom Stage 3 Long Block:
~~ Cosworth Rods, CP 8.5:1 Pistons w/ Ceramic/Moly coating on the piston tops & skirts
~~ ACL Trust Washers, Main & Rod Bearings
~~ ARP Main Studs & Rod Bolts, L19 Head Studs
~~ ATI Street Damper Crank Pulley
~~ Heads Redecked, Ported Intake/Exhaust Runners, 5-Angle Radius Cut Valve Job
~~ JWT C2 {261* w/ .456 (11.58mm) lift Intake & Exhaust} Cams
~~ JWT Heavy Duty Springs & Shims
~~ Viton Valve Seals
~~ OEM Gasket kit with Cometic Head gaskets
~~ OEM VQ35 "Rev-Up" Oil Pump
~~ OEM VQ35 Pathfinder Rear Cooling By-Pass
~~ Nismo Low Temp Thermostat
~~ Z Speed Performance Aluminum Undershroud
Fuel:
~ CJM Stage 2 Return Fuel System w/ Blue Billet Fuel Rails
~~ Aeromotive 340lph In-Tank Fuel Pump
~~ Injector Dynamics 1000cc Injectors
EMS:
~ HalTech Plug-In Pro ECU Replacement EMS
~~ HalTech Boost Control Solenoid
~~ HalTech Dual Wideband Kit w/ 2 Sensors
~~ Dual Wideband Gauge
Drivetrain:
~ Nissan CD009 (2004+) 6sp Transmission
~~ Carbonetic Twin Disc Carbon Clutch w/ Carbon/Steel Flywheel
~~ Quaife Helical LSD
~~ SPL Solid Diff Bushings
Exhaust:
~ Greddy RS Cat-Back Exhaust
~ PowerFab 3" PolyDyn Coated Downpipes
~ PolyDyn Coated Manifolds & Turbine Housings
Suspension:
~ KW Variant V3 Coilovers
~ SPL Front Upper Arms
~ SPL Rear Camber Links
~ SPL Eccentric Lockout Kit
Wheels & Tires:
~ HRE P43SC in Satin Black
~~ 19x9.5 +20 & 19x11 +25
~ Toyo R888
~~ 265/30-19 & 305/30-19
Interior/Exterior:
~ Sparco Harness Bar
~ Tommy Karia Shift ****
~ '06+ Bi-HID Headlights
~~ Custom painted by LightWerkz
Engine Code: VQ35DE
ECU: TurboXS UTEC
- Defi-Link Display
- Nismo Horns
- Optima Yellow Top
- TurboXS DTEC Map
Forced Induction:
- HKS SSQV BOV
Intake & Exhaust:
- Nismo Sides
- TEIN Hood Damper
- 15% Tint
Wheels & Tires:
2012 Build:
Fuel:
EMS:
Drivetrain:
Exhaust:
Suspension:
Wheels & Tires:
~ Toyo R888
Interior/Exterior:
Previous Dyno: 421whp & 361wtq
Dec 31, 2011:
Feb 2012:
New Plate:
Mid Feb 2012; Ready for the machine shop
PolyDyn Coated CP piston & Cosworth Rods;
Block & heads back from machine shop;
Headlights from LightWerkz;
Dec 31, 2011:
Feb 2012:
New Plate:
good looking build a+ part list, surprised your running cometic gaskets tho after all the ones that have blown on our platform
Thanks! You know after the build was returned I thought about them. But I'm hoping not to have issues.
Just talked with PowerFab...
The engine is on the stand getting timed and prepped to go in this week. The HalTech unit should arrive Wednesday. The SPL rear arms are to arrive in 1-2 weeks do to back order. Should hopefully start receiving some pictures as everything get installed.
Personal note... I went ahead and canceled my R&R for April. Still no word on Iraq starting up issuing entry Visas.
I had been looking at some steering wheels but a good friend convince me since my Z will see more street time than track to stick with the OEM wheel, airbag. Well.... Just so happens I found this FS and went ahead and picked it up. The CF was completed by Custom CF Creations.
