Stock Panamera Turbo Driftbox Data 60-130, 1/4 Mile, 0-60mph & 0-150mph
Took out my bone stock Panamera Turbo and did some baseline runs with the driftbox.
60-130 was covered in - 10.14 seconds
Here's some other data:
From a dead stop using Launch Control:
SPEED SECONDS FEET
1 0.00 0 0 Speed Start
1 10.00 0.45 3.63 Speed Line
1 20.00 0.95 14.43 Speed Line
1 30.00 1.44 32.63 Speed Line
1 40.00 2.01 62.18 Speed Line
1 50.00 2.68 106.40 Speed Line
1 60.00 3.66 185.38 Speed Line
1 70.00 4.59 274.14 Speed Line
1 80.00 5.62 387.98 Speed Line
1 90.00 6.98 557.87 Speed Line
1 100.00 8.43 759.10 Speed Line
1 110.00 10.04 1007.54 Speed Line
1 120.00 12.01 1341.10 Speed Line
1 130.00 14.44 1785.59 Speed Line
1 140.00 17.14 2321.27 Speed Line
1 150.00 20.43 3022.84 Speed Line
0-60mph: 3.66
0-100mph: 8.43
¼ mi: 11.89 @ 119.43
As per the dash board read out, right now boost pressure touches .9 bar for a split second and holds out .8-.6 bar and quickly falls off to .4 bar in the last 2,000 rpms before red line.
I will be adding the Power Box by Speedart which is supposed to bring boost pressures up to a peak of 1.2/1.3 and then sustain between 1.1-.9 bar and then fall off to .8/.7 as it closes in on red line.
If this holds true the car should perform much better.
Will have follow up data after the Power Box install in a few weeks.
Keith
SPEED SECONDS FEET
0-60mph: 3.66
0-100mph: 8.43
Keith
Thanks for posting! Please keep us update when you get the power box.
I'm also thinking of doing Techart power box but like to see your SpeedArt #'s.
Does anyone know if they will be coming out with a power box for the S anytime soon? Need more power (should have bought the TT).
