How much power does the PTTS have really (vs Mansory, PTT, M5)?
I wonder how much power the PTTS really has? It is significantly faster than the 585bhp Mansory in same mag tests (Motortrend). The M5 figures for comparison with 560bhp. Or is it the 800nm of torque that wins it for the PTTS?
Mansory 2011 Porsche Panamera Turbo (585hp)
Curb weight (f/r dist) 4590 lb (53/47%) Tires Pirelli PZero Nero, 265/30ZR22 97Y; 295/25ZR22 97Y Engine 4.8L/585-hp/623-lb-ft twin-turbo V-8 Transmission 7-sp twin-clutch auto
0-30 mph 1.2 sec
0-40 1.8
0-50 2.6
0-60 3.6
0-70 4.7
0-80 5.8
0-90 7.4
0-100 9.0
0-110 11.0
0-120 13.2
Passing, 45-65 mph 1.9
Quarter mile 12.0 sec @ 114.8 mph
Braking, 60-0 mph 107 ft Lateral acceleration 0.94 g (avg) MT Figure Eight 24.8 sec @ 0.77 g (avg)
Read more: http://www.motortrend.com/roadtests/...#ixzz1p7LJ8gaD
2012 Porsche Panamera Turbo S BASE PRICE $174,175 PRICE AS TESTED $194,665 VEHICLE LAYOUT Front engine, AWD, 4-pass, 4-door sedan ENGINE 4.8L/550-hp/553-lb-ft* twin-turbo DOHC 32-valve V-8 TRANSMISSION 7-speed twin-clutch auto. CURB WEIGHT (F/R DIST) 4388 lb (54/46%) WHEELBASE 114.9 in LENGTH x WIDTH x HEIGHT 195.6 x 76.0 x 55.8 in
0-60 MPH 3.5 sec
QUARTER MILE 11.8 sec @ 118.0 mph
BRAKING, 60-0 MPH 105 ft LATERAL ACCELERATION 1.00 g (avg) MT FIGURE EIGHT 24.4 sec @ 0.82 g (avg) EPA CITY/HWY FUEL ECON 15/23 mpg ENERGY CONSUMPTION, CITY/HWY 225/147 kW-hrs/100 miles CO2 EMISSIONS 1.09 lb/mile *590-lb-ft with overboost
Read more: http://www.motortrend.com/roadtests/...#ixzz1p7M8ydZm
First Test: 2011 Porsche Panamera Turbo
Hey Cadillac, About That "World's Fastest Sedan" Commercial...
2011 Porsche Panamera Turbo POWERTRAIN/CHASSIS DRIVETRAIN LAYOUT Front engine, AWD ENGINE TYPE Twin-turbo 90-deg V-8, alum block/heads VALVETRAIN DOHC, 4 valves/cyl DISPLACEMENT 293.3 cu in/4806 cc COMPRESSION RATIO 10.1:1 POWER (SAE NET) 500 hp @ 6000 rpm TORQUE (SAE NET) 568 lb-ft @ 3000 rpm REDLINE 6700 rpm WEIGHT TO POWER 9.0 lb/hp TRANSMISSION 7-speed twin-clutch automatic AXLE/FINAL-DRIVE RATIO 3.15:1/1.86:1 SUSPENSION, FRONT; REAR Control arms, air springs, adj shocks, anti-roll bar; multilink, air springs, adj shocks, anti-roll bar STEERING RATIO 13.8-17.1:1 TURNS LOCK-TO-LOCK 2.5 BRAKES, F;R 15.4-in vented, slotted disc; 13.8-in vented, slotted disc, ABS WHEELS 9.5 x 20-in; 11.0 x 20-in, forged aluminum TIRES 255/40ZR20 101Y;295/35ZR20 105Y
Michelin Pilot Sport PS2 DIMENSIONS WHEELBASE 114.9 in TRACK, F/R 65.2/64.8 in LENGTH x WIDTH x HEIGHT 195.6 x 76.0 x 55.8 in TURNING CIRCLE 39.3 ft CURB WEIGHT 4486 lb WEIGHT DIST., F/R 54/46% SEATING CAPACITY 4 HEADROOM, F/M/R 38.0/38.2 in LEGROOM, F/M/R 41.9/33.3 in SHOULDER ROOM, F/M/R 51.9/51.7 in CARGO VOLUME, F/M/R 15.7 cu ft TEST DATA
ACCELERATION TO MPH
0-30 1.2 sec
0-40 1.7
0-50 2.5
0-60 3.5
0-70 4.5
0-80 5.6
0-90 7.2
0-100 8.8
PASSING, 45-65 MPH 1.9 QUARTER MILE 11.9 sec @ 114.7 mph BRAKING, 60-0 MPH 109 ft LATERAL ACCELERATION 1.00 g (avg) MT FIGURE EIGHT 24.4 sec @ 0.81 g (avg) TOP-GEAR REVS @ 60 MPH 1400 rpm
Read more: http://www.motortrend.com/roadtests/...#ixzz1p7MwRNPz
2013 BMW M5 POWERTRAIN/CHASSIS DRIVETRAIN LAYOUTFront engine, RWD ENGINE TYPETwin-turbo 90-deg V-8, alum block/heads VALVETRAINDOHC, 4 valves/cyl DISPLACEMENT268.2 cu in/4395 cc COMPRESSION RATIO10.0:1 POWER (SAE NET)560 hp @ 6000 rpm TORQUE (SAE NET)500 lb-ft @ 1500 rpm REDLINE7200 rpm WEIGHT TO POWER7.8 lb/hp TRANSMISSION7-speed twin-clutch auto AXLE/FINAL-DRIVE RATIO3.15:1/2.12:1 SUSPENSION, FRONT; REARMulti-link, coil springs, adj shocks, anti-roll bar; multi-link, coil springs, adj shocks, anti-roll bar STEERING RATIO13.1:1 TURNS LOCK-TO-LOCK2.5 BRAKES, F;R15.7-in vented, drilled disc; 15.6-in vented, drilled disc, ABS WHEELS9.0 x 20-in, 10.0 x 20-in cast aluminum TIRES265/35ZR20 99Y; 295/30ZR20 101Y Michelin Pilot Super Sport DIMENSIONS WHEELBASE116.7 in TRACK, F/R64.1/62.3 in LENGTH x WIDTH x HEIGHT193.5 x 74.4 x 57.3 TURNING CIRCLE41.3 ft CURB WEIGHT4384 lb WEIGHT DIST., F/R52/48 % SEATING CAPACITY5 HEADROOM, F/R40.5/38.3 in LEGROOM, F/R41.4/36.1 in SHOULDER ROOM, F/R58.3/56.2 in CARGO VOLUME14.0 cu ft TEST DATA
ACCELERATION TO MPH
0-301.5 sec
0-402.2
0-502.9
0-603.7
0-704.7
0-805.8
0-907.0
0-1008.4
PASSING, 45-65 MPH1.6
QUARTER MILE11.9 sec @ 120.3 mph BRAKING, 60-0 MPH110 ft LATERAL ACCELERATION0.94 g (avg) MT FIGURE EIGHT24.9 sec @ 0.81 g (avg) TOP-GEAR REVS @ 60 MPH1500 rpm
Read more: http://www.motortrend.com/roadtests/...#ixzz1p7NeynKu
0-30 mph 1.2 sec
0-40 1.8
0-50 2.6
0-60 3.6
0-70 4.7
0-80 5.8
0-90 7.4
0-100 9.0
0-110 11.0
0-120 13.2
0-60 MPH 3.5 sec
ACCELERATION TO MPH
0-30 1.2 sec
0-40 1.7
0-50 2.5
0-60 3.5
0-70 4.5
0-80 5.6
0-90 7.2
0-100 8.8
ACCELERATION TO MPH
0-301.5 sec
0-402.2
0-502.9
0-603.7
0-704.7
0-805.8
0-907.0
0-1008.4
My point was 2 slower cars have more power, so how underrated are the PTT and S. What this thread turned up to be, however, was that one should be carefull with aftermarket aerokits
If the aerokit is an attempt to make the Panny prettier, or meaner looking or more purposeful in some way, it's a fail. Not a big fan of aerokits in general, particularly not on a sedan. The fact that it is somehow SLOWER just makes no sense to me. The Sport Design kit, ala the GTS, just seems more natural.
I may be in the minority, but I like the way the stock Panny looks, particularly the GTS. This car doesn't need any bling.
Probably a little about the P-cars understating and more about others overstating. Does appear that the Mansory car is not making near the power advertised, may actually be making less than stock (closer to a GTS than a PTT, no?). The M5 is pulling on the PTTS on top, so that may be close to a "real" number. Little surprised that the PTTS does not pull the "base" PTT by that much... that base 500 hp number may be a little low. As far as the kit goes, it isn't better looking and it is slower; that's definitely a win-win.
Here is a base PTT dyno:
Here is what other tuners have gotten. Seems the Panny is not a tuner friendly car, so I dont think a famous tuner like Mansory would not deliver bhp that is promised:
Techart 580ps/830nm
0-100km/h 3.8
0-200km/h 12.5
http://www.sportauto-online.de/fahrb...r-2745538.html
SpeedArt 560bhp/810nm
0-100km/h 3,9
0-200km/h 13.6
SPortec 575bhp/820nm
0-100km/h 3,9
0-200km/h 13.6
http://www.sportauto-online.de/vergl...o-2778817.html
SPortec 565bhp
0-100km/h 4.0
0-200km/h 13.2
0-300km/h 52.8 (Comparison above PTTS 40,7s)
Still the best times ever posted are Panamera Turbo with Powerkit (540bhp/800nm). Could this be that this car has the mechanical LSD vs the PTV with electronic LSD in the PTTS and new PTT:
0-100km/h 3,6s
0-200km/h 11,8s
1/4 mile 11,53s
Uploaded with ImageShack.us
Techart 580ps/830nm
0-100km/h 3.8
0-200km/h 12.5
0-100km/h 3,9
0-200km/h 13.6
0-100km/h 3,9
0-200km/h 13.6
SPortec 565bhp
0-100km/h 4.0
0-200km/h 13.2
0-100km/h 3,6s
0-200km/h 11,8s
1/4 mile 11,53s
Seriously, most tuners exaggerate the hp claims. Yes, there are a handful of tuners that do not...but I would not throw Mansory in that group...they are more known for their crazy aesthetics than proven power.
People can blame the aero kit and the heavy wheels on the Mansory PTT....but up to 100mph...a 85hp increase should more than make up for the additional aerodynamic drag and heavier wheels. That car is just not making the power they are claiming to be making. It happens all the time with tuners. I have had many cars that I have modified and found the claims to be mostly BS when actually tested on the dyno and at the strip....and the tunes were done by some pretty reputable tuners. That is why I also prefer custom dyno tuning over the generic canned tunes...because you can see the tangible difference on your exact car...not what it did on some other car. I think Mansory just sent over their canned tune to the U.S. distributor and never tested to see if it was making the claimed power. They probably needed to tweak something...maybe even for the quality of the gasoline used.
Tom
Then you must not modify your cars much!
Tom
Tom
I get that they dont make the hp promised, but slower than the original, isnt that wierd??
Ferrari
08-24-2015 04:35 PM
