Getting low MPG on my panamera 4
I just crossed 1000 miles on my p4.
I checked the mpg and its only showing 16.1 MPG.
I drove quite conservative during the initial 1000 mileage.
I'm about 60% highway and 40% city.
Doesn't this seem quite low and do you think I should give it more time before assessing if there is an issue.
I haven't had any low oil warnings either if that matters.
I drove quite conservative for the first 1k miles. And in general I don't brake hard or accelerate full throttle often which is why I am a bit worried that the mileage is on the lower end.
Do you have the auto on/off function turned off? Are the tire pressures OK? Are you using the on-board computer to calculate mpg or are you basing on miles travelled/gallons used at fill-up? Are you using a/c all the time? Is it possible a disc brake is stuck and dragging-- does the car pull to one side?
also when i first got the car,i called the salesman up and said,"boy i get to 7th gear pretty fast and at a low speed".he said that`s the reason you will get such great gas mileage.
there is definatly something wrong
ModBargains
997 Vendor Classifieds
10-13-2015 03:53 PM
ModBargains
Ferrari Vendor Classifieds
10-13-2015 03:47 PM
ModBargains
10-13-2015 03:45 PM
