1st Time porsche owner lil help please
Just picked dup my first Porsche Panamera 4 2014. I traded an LS 460 which I loved but wanted some new youthful styling...
I am loving this car expect for one major problem. A seriously annoying high pitch sound that occurs fairly often... The sound is similar to microphone feedback or a very high pitch whistle. I am certain it is related to the engine... I have seen a few other posts and plan to look closer at them. The car has 700 miles on it. I brought it back and the service manager advised me the following. "The car is fine, You will learn to live with it, You need to understand this is a much louder car then your previous car, turn the radio up, you will get use to it, nothing we can do" I am thinking for $100K + car there has to be something they can do. I really want this to work out as I love the car outside of this problem. I would greatly appreciate any advice on this unfortunate issue. Best wishes....
Brian
Brian
Brian
Brian
Since you live in my area I have to ask, what dealer told you that? A couple things that come to mind, did you hear this noise when you test drove the car? Does it make the noise when it idles? Is it possible the noise is coming from the wheels and not the engine? I think the service manager's comment was unprofessional and ignorant and is not likely to get the dealer repeat business. Yes your Lexus is a more isolated type of car but turn the radio up and get used to it is not how you deal with a customers issue. I have a fairly good relationship to the local dealers (you tend to get that after 40 Porsche's) and I think the principals would want to know that they have someone working for them that would tell a customer that. I know I would.
I have a 2012 turbo s, and I will sometimes hear a suttle noise which seems to be coming from the front. I turn down the fan speed on my AC, and it goes away. I don't know if this helps, but let me know if that changes your situation any.
I had a 2014 and I can't recall a noise like that. I was going to say it might be the turbo spooling up but you have the NA version of the engine.
I did have the thermal insulated windows that could of kept the noise out...
I had the high pitch noise and got it solved by first diagnosing the location on the hatch which can cause a whistling sound at certain speeds. Used carpenter tape to cover the gap for entire hatch. Remove sections of the tape till you realize which section is causing grief. Then take it to the dealer and tell them to adjust the hatch. Should take less than 5 minutes.
Hi,
I have a 2013 Panamera 4 that exhibits a similar high pitched noise. I have taken it to the dealer several times and every time they fix it, the sound comes back after a few days:
Work completed:
-water pump replaced
-tension pulley replaced
I noticed that it is most prominent at 1800 RPM in 7th gear, which is roughly around 64-66 mph on the freeway. The dealer has been helpful but not willing to replace every pulley or bearing to see if it is causing the noise.
It seems very similar to the problems that are being discussed in this thread... Has anyone determined a way to debug the source of the sound?
Work completed:
my car is finally back from service and I still can hear the high pitched noise. My SA said that everything seemed to be normal and there is no open campaign on my car or any fault code. I looked through older post and found that pre facelift panamera with AWD have this noise. Porsche did release an official fix for it however when I showed the service ticket to my SA he said the fix doesn't apply to my car.
