Panamera S 2013 Brake Rotor Specs
Old 06-27-2016 | 09:27 AM
danilonovelli's Avatar
danilonovelli is infamous around these parts
Hi... does anyone know what the rotor thickness specs are for front and back and also minimum thickness for Panamera S 2013 (v8)? Thanks!
Old 06-27-2016 | 09:53 AM
allroadusa's Avatar
allroadusa has a spectacular aura aboutallroadusa has a spectacular aura about
Here you go :
Fitting Position: Front Axle
Diameter: 360 mm
Brake Disc Type: Vented
Brake Disc Thickness: 36 mm
Minimum thickness: 34 mm
Fitting Position: Rear Axle
Diameter: 330 mm
Brake Disc Type: Internally Vented
Brake Disc Thickness: 28 mm
Minimum thickness: 26 mm
Old 06-27-2016 | 10:01 AM
awesome... thanks Allroadusa!
Splatter00
05-08-2016 10:39 PM
nitrorocket
05-01-2016 03:26 AM
Quick Reply: Panamera S 2013 Brake Rotor Specs
