Most aggressive offset for air suspension
Hi all,
I've recently picked up a P4S with air suspension and was thinking of changing to a 20 to 22 wheels setup. Now, while looking thru some of the information on the Internet, my ride suddenly encountered some issues with the air suspension causing it to drop to a very low level by itself and I noticed that the tires are right under fender.
Having said that, it prompts me the question that if I had opted for an offset that flushed with the fender wouldn't it be a problem if the air suspension gave way?
So the magic question is that for all bros running aggressive offsets, what's the maximum offsets to run without having to worry about issues when the air suspension drops all the way down?
Thanks in advance. Cheers
This thread answer your questions. Check benblack`s info regarding his sick setup.
https://www.6speedonline.com/forums/...22-wheels.html
