Adding Techron bottle to gas tank '10 Panamera S ? Anyone done?
Old 03-17-2018 | 12:14 PM
newporsche's Avatar
newporsche is infamous around these parts
Hey all, 2010 panamera i notice sometimes quite a bit of smoke and high oil consumption, i was recommended maybe the engine needs to be cleaned and was recommended to put a bottle of techron in the fuel tank before my next gas fill up. Is this ok for a 2010 Panamera S? can i just put a bottle in before my next fill up?
Old 03-17-2018 | 02:26 PM
cerbomark's Avatar
cerbomark Is a GOD !cerbomark Is a GOD !cerbomark Is a GOD !cerbomark Is a GOD !cerbomark Is a GOD !cerbomark Is a GOD !cerbomark Is a GOD !cerbomark Is a GOD !cerbomark Is a GOD !cerbomark Is a GOD !cerbomark Is a GOD !
Not going to hurt but I don t think it will help your situation either.
Old 03-17-2018 | 03:41 PM
orangeokie's Avatar
orangeokie is infamous around these parts
I use Techron regularly in all of my vehicles. It is the best additive on the market IMO, and I use Chevron gasoline where ever I can find it. Additives are not going to repair your engine however.
Old 03-17-2018 | 09:06 PM
knowspin's Avatar
knowspin has a spectacular aura aboutknowspin has a spectacular aura aboutknowspin has a spectacular aura about
Techron will help clean your valves (unless your engine has direct injection), but won't do anything for high oil consumption. Have a compression test done.
Old 03-18-2018 | 01:37 AM
dougcayenne's Avatar
dougcayenne has a spectacular aura aboutdougcayenne has a spectacular aura aboutdougcayenne has a spectacular aura about
Oh Boys. I see $$$ spending to fix the car. Hope you don't have any serious valve stem leaking. Please check your spark plug to see you have any oil.
Hope you have a good mechanic or Indy guy to fix your car. Techron won't work and do nothing.
Good luck !!!
Old 03-18-2018 | 10:27 AM
newporsche's Avatar
the reason i asked is because i read online that carbon buildup can lead to higher oil consumption and that techron can help with the carbon buildup
Old 03-18-2018 | 11:05 AM
cerbomark's Avatar
I think his 2010 may be direct injection...
usually not an issue until higher miles, didn t see how many on your car?
I also agree that this all has nothing to do with oil consumption IMO.
Old 03-18-2018 | 12:27 PM
djantlive's Avatar
You using the 0w40 Mobile one oil?
Old 03-18-2018 | 12:50 PM
riden's Avatar
riden has a spectacular aura aboutriden has a spectacular aura aboutriden has a spectacular aura about
I would do the compression test or use a camera to determine the cylinder condition. Too many unknowns to come to any conclusion.
Old 03-20-2018 | 11:29 PM
newporsche's Avatar
hey dj im not sure what the last dealer used for the oil change, but i am due for another oil change soon, any oil you all recommend?
Old 03-21-2018 | 03:32 PM
knowspin's Avatar
I would check your owner's manual and do what they specify for your engine.
infinkc
01-16-2017 11:01 PM
vrnkc
08-01-2014 06:54 AM
sharkster
10-06-2003 08:09 AM
Quick Reply: Adding Techron bottle to gas tank '10 Panamera S ? Anyone done?
