Brighter reverse lights?? 2016 Panamera GTS
I'm all ears when you find a good solution; I need more light back there too!
Skiracer13.....if you find a way to replace the reverse lights on vehicles that don't have the removable cover, please share with the community.
Just doesn't make any sense that those bulbs wouldn't somehow be replaceable.
I couldn't see an obvious way to do it..…..hope you can figure it out.
The video link provided by DogWood did the trick - just needed to remove 2 more Torx bolts to access the bulb holder. Unfortunately I don't have the right size bulb in my LED inventory so I ordered a pair of these (kind of pricey - but I went w/ the highest output which are also the shorter so they should fit better):
https://www.carid.com/lumen/tail-lig...IaAlHCEALw_wcB
I should have them installed in a week or so and will report back.
Good to hear skiracer13
I'm thinking of going with these: https://www.ddmtuning.com/Products/1156Canbus-42x3030
1100 lumens!
1100 lumens!
Glad the video helped some of you guys out.
Looked at the carcarkiosk video that Dogwood posted.
In part 2 of the video, about 34 seconds into it, the reverse light cover is removed by unscrewing one torx screw (which then exposes the bulb holder that is held on by 2 other torx screws).
Unfortunately, for some reason, my reverse light cover has no screw to remove the reverse light cover.
It seems like the cover and housing assembly are molded together in one piece (see pic I posted.
Any help with my dilemma to access the reverse light would still be appreciated.
I have a 2013 GTS and I've wanted to replace my reverse lights as well, so I'll need to check the housing tonight.
Well I finally had the chance to really dig into this issue w/ some help from a mechanic/friend but ended up hitting a wall. It turns out the bulb is soldered to the mounts of Porsche's proprietary reverse bulb socket - after prying the soldered connections loose and finally removing the bulb I determined the following:
1. The 1156 replacement bulb that all sites point to is too large to fit in the socket.
2. The proprietary socket that Porsche put into the Panny will not hold an 1156 bulb even if I could somehow establish an electrical connection - it would just fall out or vibrate loose over time.
So I re-installed the factory bulb and dealing w/ the reality that this situation can't be improved upon. What is required is an 1156-compatible socket that will replace Porsche's proprietary device and plug into the existing connectors.
Bummer!
Bummer!
Pulled mine apart for a better look, bulb is a PHIL16W, did a quick search, seems the base is actually part of the bulb - more of an assembly than just a bulb.
Found this: looks familiar, says Audi,BMW but not Porsche - I suspect we will need something along this line and not a simple bulb
Found this: https://www.amazon.com/GFJMC-Backup-...keywords=ph16w
The Amazon set I ordered arrived today and I successfully installed them per the procedure and photo's below. I'm not seeing the lighting improvement I was hoping for, but will try again when it gets dark. The 2nd side took me less than 5 mins w/ no pics to take along the way!
Pic w/ OEM reverse lights on
Tools needed: T25 torx, T15 torx and a pry tool
Pry off cover panel
Remove single fastener w/ T25 torx
Pull entire light ***'y rearward to remove
No need to disconnect connector - simply lay the ***'y on its side on the shelf
Remove reverse light bulb cover w/ T15 torx
Remove 2 fixture fasteners w/ T15 torx
Pull out bulb fixture and remove 2 end connectors - simply pull off firmly
New LED fixture looks like it should fit
Install new LED bulb fixture using same polarity as OEM fixture
I applied double-sided tape to secure the resistor pack to the inside of the cavity, plenty of space. Reverse entire procedure to put back together then do the other side.
New LED reverse lights successfully installed, no errors present. These are 30W bulbs and I wish they were 100W!
Pry off cover panel
Nice, glad to hear that they fit OK, is then first picture a "before"? Last picture looks whiter and brighter.
I hear you on the the 30W, there are some sketcher ones claiming up to 80W! foot print is a bit odd and reviews where mixed.
Lumens would be a better measurement to go by
