Brighter reverse lights?? 2016 Panamera GTS
Old 04-27-2023 | 11:17 AM
ZDPRx's Avatar
ZDPRx is infamous around these parts
I cut mine open.
I cut mine open with a Dremel tool. It looked exactly like the other pics posted here with the access door. I installed the new bulbs and used a bit of duct tape to seal it. No problems, plug and play...all good.
  #92
Old 04-27-2023 | 11:45 AM
Kayvan1347's Avatar
Kayvan1347 is infamous around these parts
thanks for the information.
finally someone was brave to do this. Did you take any pictures? Where you you cut? I like to do it just not as brave as you. If you can show more detail how to do this would be appreciated.
thanks
  #93
Old 04-27-2023 | 09:17 PM
vkb123's Avatar
vkb123 has a reputation beyond reputevkb123 has a reputation beyond reputevkb123 has a reputation beyond reputevkb123 has a reputation beyond reputevkb123 has a reputation beyond reputevkb123 has a reputation beyond reputevkb123 has a reputation beyond reputevkb123 has a reputation beyond reputevkb123 has a reputation beyond reputevkb123 has a reputation beyond reputevkb123 has a reputation beyond repute
Also interested in pics of the DIY.
  #94
Old 04-27-2023 | 10:44 PM
DogWood's Avatar
DogWood is infamous around these partsDogWood is infamous around these parts
good info, thanks for sharing
  #95
Old 05-22-2023 | 05:03 PM
Kayvan1347's Avatar
I did mine today as well. I use Dremel to cut around the opening using a very fine disc, just be carful don’t go too deep since you may cut the wire specifically on back side. Check the picture. The rest is just plug and pla.
  #96
Old 05-22-2023 | 06:20 PM
970gts's Avatar
970gts is infamous around these parts
Like vkb123, I think my reverse lights might be LED as well, since the light seems very white (2015 GTS … I used to have a 2013 GTS where I mounted 2 Oznium lights on either side of the license plate). Curious, (you have a 2014 S?), is the reverse bulb on yours incandescent or LED?
  #97
Old 05-22-2023 | 08:27 PM
vkb123's Avatar
I was told 970.2 has LED reverse lights. I would be interested in hearing others thoughts as well.
  #98
Old 05-23-2023 | 01:40 AM
Kayvan1347's Avatar
Mine was 2013 model. I also heard 970.2 are already LED I think just. 2009 to 2013 model can upgrade to LED.
I was wondering if anyone upgrade the front headlights bulbs to LED bulb also?
Dahl0113
10-24-2021 10:20 PM
PP7173
01-25-2021 10:32 AM
iammulva
09-11-2019 04:19 PM
ciaka
01-30-2019 12:29 AM
cfpchfc1
04-07-2015 10:43 PM
