Swaybar bushing replacement - has anybody taken off the "Front-axle support brace" ?
In order to replace the sway bar bushings I need drop both the sway bar ("anti-roll-bar") and the support brace ("Rear Front-Axle Support") which holds it in place.
Now, before I start unbolting this puppy I wanted to obtain some insights from those of you who have removed said brace. It is held in place by 12 bolts and seems to be part of the structural rigidity of the car. As background information, my car is currently lifted on a 2 post lift.
Questions :
1] Is it safe to remove this brace with the car lifted on it's regular 4 lift points ?
2] What are the torque settings for these 12 bolts ? I couldn't find it anywhere in the 12K page Shop Manual.
Attached some pics, both from the manual and what is currently going on in my garage. Once i get this figured out I will post a DIY.
From shop manual
Live, from my shop
Here you can see have the brace holds the bushings and sway bar in place
Thank you in advance for your help !
Questions :
From shop manual
Live, from my shop
Yves, look on page 10898, it looks like the torque specs for those bolts, but the image doesn't have the numbers
I suspect we could figure it out based on the bolt diameter
hopefully someone has a good definite answer
I'll operate the lift on Saturday, you can get under the car and undo the bolts
All you have to do, is lower that entire x-brace down.. Dont remove it comletely, just lower it down... the bolts are pretty darn long and just thread it in about 3-4 revolutions. Its a combination of 16mm and 18mm nuts... Make sure you dont loosen the steering rack 18mm bolt.... Once you lower it, pull the bottom bushings off from the inside-to-out. You can also pull down on the sway bar and it will stay and hold in place, so that you can pull off the upper portion of the bushing. You can remove all the bolts except for the 4 bolts hold the sway bar bushing in place. Make sure you clean off the surface on the X-brace where the bushing will be sitting on... Also, make sure you lube your new bushings with marine grease. Yes, the bushings will look like its too small for the bar, but trust me, it will fit once you torque in the x-brace.
You dont need to worry about those two rope strap things, the bar is not under much tension. You'll need to actually pull on the bar to pull off the top bushing. It'll stay in place once you pull it down. Once you have the bushing in place, just push the bar up... Make sure you also lube the surface of the bushing-bar surface as well...
Dude, Doug, I have a bunch of stuff to load up, but I keep having more cool projects going, so its been a little tough, hahaha. I guess, its better to post these up just in case for anyone else in the future.
Alex, thank you so much for the information.
As Doug indicates, the brace came off, however, without any drama. There's just too much pot being grown and IPA being brewn here in Central Oregon, sometimes I worry about my fellow PCA members
The ropes were actually used to tie the swaybar to the chassis so it couldn't drop when the brace was removed. This is also the procedure as explained in the mechanics manual.
On a different note, I noticed that the new swaybar bushings are WAY smaller than the old ones. Since they simply won't fit I called the Porsche dealership where I bought them and they admitted mistake. Apparently there are 2 different sizes bushings. My car is a Turbo S, so it may have a more beefed up sway bar, don't know.
The parts they initially sent me were ;
upper bushings (Porsche 97034379205)
lower bushings (Porsche 97034379305)
From what I was explained the parts for my car should end in "07" as opposed to "05"
