Radiator Hose Came Undone WTF
Question: Since coolant sprayed everywhere, should I request an engine compartment detail? is this a reasonable request? Or will they just use a rag to clean? I have been wanting to do a detail since I bought it.
I see a lot of coolants note a paint test where they test the corrosive effect to be neglibgle. But I would think that cleaning up would be part of the repair...
I looked as best as I could with a scope and our '13 has the same unbolted design! Different adhesive maybe, or just hasn't reached the age/mileage? Relatively I would expect '10, '11, '12, then '13 motors to have the failure in that order.
Have been hesitant to order the thermostat housing as I'm already sitting on top of a lot of parts and fluids...
Forgot to mention that dealership thought it was ok to return my car with radiator fluid sprayed all over engine compartment. I could smell it from 10 feet away. The service advisor said it would “burn off”. So I got pretty pissed, and I even had to go to talk to the detail folks to get it done (only spoke Spanish). Luckily I speak Spanish. But I didn’t have to do all that. Car runs well again and got a full engine detail at no cost. And I also saw how they did it so I can do myself next time.
My wife likes to give nicknames to her cars. The Porsche to her became Pannini. I decided to rename her "Check Engine Light, Once a Week"!
panatela, what year and how many miles do you have on your Panamera? I'm taking the stock plenum off right now and anything else that I can easily remove. Hope I'll be able to see if I have the updated thermostat housing.
Not sure if it's even called the plenum but that black plastic Y piece in the front. I was able to see a little better and it doesn't look like it's the updated thermostat housing. The joint seems to be ok and almost like a nice bead around it, but who knows.
