whee/tire fitment advice
Hello Forum,
I wanted to get an idea if the following wheels/tires would fit my 2014 PSEH. More concerned about the offset on the front wheel. Here are the wheel/tire specs:
20 x9.5 x 71mm ET
20x11.5 x 68mm ET
Tires: Michelin
Pilot sport A/S3
275/ 40 r20
315/ 35 r20
Appreciate any feedback.
Thanks,
bongsta
20 x9.5 x 71mm ET
20x11.5 x 68mm ET
Tires: Michelin
Pilot sport A/S3
275/ 40 r20
315/ 35 r20
Thanks,
bongsta
The offset for the stock 20 inch front wheel is 65mm and the rear is 68mm so this will be pulled in a bit much versus the stock fitment. You could just add a wheel spacer up front, say a 7 mm to keep the stock offset look and clear the brakes. If you need more clearance, depending on the wheel style, you could do a 15 mm up front and out back. You will likely have to test fit the wheels for clearance.
Thanks, it is a fun car. No issues with the spacers. Just need to make sure they are a good quality. I did get longer wheel bolts for the back with the 15 mm spacers. I forget the stock specs but if I recall, I used 43mm bolts.
mlandingin177
08-21-2019 06:17 PM
