Sign of bad oil pump or oil pressure sender?
Recently I was driving my 2011 PTT with about 62k miles and noticed the oil pressure gauge going much higher than usual (close to 5) at maybe 5psi boost and not WOT. Then yellow oil pressure fault light came on and the gauge went to zero and stayed there, oil levels remain fine and still boosting normal. The light would then go away and gauge would work again, but still abnormally high (has been very hot this past week or 2 in the northeast, not sure if that's a factor)
Looking to order a new oil pressure sender today if anyone has experienced same issue..... thanks guys
Haven't had chance to scan but I am about 4-5k into oil change. Just ordered sender, having installed tomorrow, let's see how it goes
Did you ever figured out the culprit for the error code by chance? I'm having the exact same issue.
Really? I changed mine and still does the same thing, oil pressure goes to zero once I hit over 72mph and returns to normal once I drop speed or RPM's drop to under 3k. Around town it never shows its ugly head but on freeway it does. What exactly did yours do?
Didn't have issue again after changing.
