Chassis Ground Connections - where?
Old 02-05-2021 | 10:59 AM
Kirkman's Avatar
Kirkman is infamous around these parts
I've had my '17 Turbo since early October. Sometimes I get a warning signal that the seat belt is not connected (it is) and that the adaptive cruise control needs servicing.
Wondered if these two items were on the same circuit - thus blown fuse. But no, on start-up after overnight no warning signals whatsoever. Concluded that the circuit(s) fuses are operative.
Former owner of this car lived in Newport Beach, CA - in the "salt air zone." Salt air can cause corrosion of chassis ground points. I cleaned the battery posts, but this problem continues. I'd like to clean any the chassis ground connection, which I think exists. If so, where is it?
Old 02-06-2021 | 10:58 AM
shrike071's Avatar
shrike071 has much to be proud ofshrike071 has much to be proud ofshrike071 has much to be proud ofshrike071 has much to be proud ofshrike071 has much to be proud ofshrike071 has much to be proud ofshrike071 has much to be proud ofshrike071 has much to be proud of
usually, there's a fat ground at the engine block - that's one of the main ones.
Old 02-07-2021 | 03:43 PM
jzchen's Avatar
jzchen is infamous around these parts
Hopefully the seatbelt warning issue is local to the belt and latch areas. Is the warning the seatbelt unbuckled?
Old 02-07-2021 | 09:48 PM
Kirkman's Avatar
The seatbelt warning came on when the seatbelt was fastened. I unfastened the seat belt and refastened - still the warning. Problem ceased after an overnight cool down as mentioned above.
On ground straps: I've seen high-end audio shops install additional grounds to head units and amplifiers
pupdogg
Bentley
11
06-27-2021 05:41 PM
Steve Gatsby
Cayenne 955/957
12-17-2017 02:36 PM
pgaATX
Cayenne 955/957
10
12-20-2012 11:46 AM
vanhogh
03-08-2012 09:02 PM
nelsonmx
Cayenne 955/957
11-04-2010 09:35 AM
Quick Reply: Chassis Ground Connections - where?
