Brake pad sensor - in case you need to know...
Brake pad sensor testing - in case you need to know...
Had a warning pop on the dash. Odd, since I just did a complete brake job, so my guess was a bad sensor. Testing them is super easy - you just need a multimeter set to Ohms, and you don't need to remove anything from the car. Get the car in the air -ramps will do. Unplug the sensor, stick the leads in to the sensor side of the plug, look at your meter. The proper resistance in a good sensor is .2-.3 ohms and a bad one will be '0'. You also can replace the wear sensor without having to remove the caliper from the car. Once you locate the bad corner, it's about a 5 minute job. Remove the wheel, use needle nose pliers to pull out the sensor. Insert the new one, plug it up, mount the wheel and you're done.
