Panamera Turbo 2012 - Revs high before engaging into gears
Hi All,
I have a Panamera Turbo 2012 with about 70K on the clock. I had a problem with it not engaging in gears and it was taken into a garage who quickly noticed it had an transmission oil leak, he repaired the oil leak and changed the transmission oil, however after doing so it revs high ( 2000 RPM ) before going into 3rd gear! The Panamera sets off in 2nd gear but you need to really rev it high before it goes into 3rd. Gears after 3rd seem fine and change as they should. It also revs high when reversing. Has anyone experienced this issue. Any help would be greatly appreciated.
Regards
Lee
Regards
Lee
Depends on what was involved in repairing the leak. Some work requires the solenoid pack to be cycled when refilling the fluid. That can only be done with a PIWIS. It may also be worth checking the fluid level again.
