2014 Rapide S Rough Cold Start
I am experiencing a slight issue with my new Rapide S. Since new (by now car has run 600 km) I would experience a rough idle for about 10 seconds at cold starts. Engine idles rough and seems to stutter and wont acccept accelerator Input. After 8-10 seconds it settles and all is fine.
Later warm starts do not exhibit any issues and car starts normal, only to do the same and the next cold start a day later after it had settled over night.
I took the car to the dealer who could not pull any codes and updated to the latest ECU Software to no avail. The issue remains.
Other than that, the car runs jut perfect an exhibits no Anomalie at all.
Any ideas ?
Any ideas ?
DonL, I have used different suppliers. There was a AM campaign concerning the rough idle at cold start. My dealer supposedly updated to the latest Software that should take care of that Problem.
Unfortunately the issue has still not been resolved.
Furthermore, I believe that if it was fuel related, it would exhibit the same issue at any start not just at cold starts.
My 2009 DBS did this recently. Rough idle on cold start, by the time I got to work the engine was running smoothly. Did this off and on.
It finally threw a code. P0174. I thought either dirty MAF or sticky/dirty fuel injector. I ruled out the MAF because of the off an on nature of the rough idle/misfire. (Long story of reasoning behind this) I cleared the code and put a bottle of fuel injector cleaner with last tank of gas and have just about used that up. Have not experienced the issue since.
Your 2014 is 5 model years newer so I don't know exactly what your issue is. But a bottle of fuel injector cleaner is fairly inexpensive. You might try it.
thanks for the Input. my issue seems very similar to yours. however, it showed this from new (30kms on odo) so i doubt it is mechanical/electrical and am leaning more towards ecu. my dealer said they willreflash the ecu....will come back with update..
With only 600km's or so, you still could have some "poor" fuel remaining in your tank.
