Bentley Continental GT 2004 rear windows not working
Hello!
There is a new problem with my Conti.
The rear windows stopped working.
Tell me, what could it be?
I will be grateful for any help
Diagnostic showed these errors:
VCDS Version: Release 12.12.0 (x64)
Data version: 20130910
Chassis Type: 3W (3W - Bentley Continental (2004 > 2006))
Scan: 01 02 03 05 06 07 08 09 11 13 15 16 17 18 19 23 26 28 34 36
37 38 46 47 53 54 57 65 66 68 69 6C 71 75 76 77
Address 01: Engine Labels: 07C-906-018-BEB1.clb
Part No SW: 07C 906 018 AC HW:
Component: BY-6.0L-TT G ª6238
Coding: 0000173
Shop #: WSC 07800 107 59862
VCID: 66C350135292162E0EF-50E6
1 Fault Found:
18331 - Please Check DTC Memory of ECU Number 2
P1923 - 008 -
Readiness: 0110 1101
Address 02: Auto Trans Labels: 09E-927-156.lbl
Part No SW: 09E 927 760 A HW: GS1 9.0 4.1
Component: AG6 09E 6.0L W12TT 1004
Coding: 0000101
Shop #: WSC 00083 000 00000
VCID: 2E53E833BAE29E6E36F-5072
No fault code found.
Address 03: ABS Brakes Labels: 3W0-614-517-V1.lbl
Part No: 3W0 614 517 B
Component: ESP 5.7 4WD H01 0011
Coding: 0007878
Shop #: WSC 07708 000 00000
VCID: 3467FA5B54CEB4BE40B-5000
Address 05: Acc/Start Auth. Labels: 3D0-909-13x-05.lbl
Part No SW: 3D0 909 135 M HW: 5WK 470 26
Component: 11 Kessy 6400
Coding: 0131309
VCID: 2F6DF537BDE897663D9-5072
Subsystem 1 - Part No: XXXXXXXXXXX
Component: ELV XXXX
2 Faults Found:
01333 - Door Control Module; Rear Left (J388)
004 - No Signal/Communication
01334 - Door Control Module; Rear Right (J389)
Address 06: Seat Mem. Pass Labels: None
Part No: 3W0 959 759 A
Component: CM Seat Pass. 0009
Coding: 0000002
Shop #: WSC 07708 108 181447
VCID: 479DBD9735582F26159-5072
1 Fault Found:
02569 - Control Module for Massage (J740)
009 - Open or Short to Ground
Address 07: Control Head Labels: 3D0-035-00x-07.lbl
Part No: 3W0 035 008 F
Component: ZAB COCKPIT 0251
Coding: 0400335
VCID: 306FF64BA0D6889E243-5072
3 Faults Found:
01325 - Control Module for Tire Pressure Monitoring (J502)
Address 08: Auto HVAC Labels: None
Part No: 3W0 907 040 A
Component: Climatronic BY614 0030
Coding: 0000001
Shop #: WSC 98765 666 30877
Address 09: Cent. Elect. Labels: 3D0-937-049-V1.clb
Part No: 3D0 937 049 G
Component: STG.Bordnetz 5001
Coding: 0000105
Address 11: Engine II Labels: 07C-906-018-BEB2.clb
Coding: 0000173
VCID: 66C350135292162E0EF-5072
Address 15: Airbags Labels: 3D0-909-601.lbl
Part No: 3D0 909 601 D
Component: 0H Airbag 8.4E+ H07 0936
Coding: 0012360
VCID: 24470A1BE42E243ED0B-5072
Address 16: Steering wheel Labels: 3D0-953-549.lbl
Part No: 3D0 953 549 D
Component: Lenksäulenmodul 3401
Coding: 0000012
Address 17: Instruments Labels: 3Wx-920-xxx-17.lbl
Part No: 3W0 920 840 P
Component: KOMBIINSTRUMENT RB4 0401
Coding: 0021100
VCID: 4189A38F1B7C1116DBD-5072
Address 19: CAN Gateway Labels: 6N0-909-901-19.lbl
Part No: 6N0 909 901
Component: Gateway K<>CAN 0101
Coding: 0000006
VCID: F0EFB64BE056489EE43-5072
Address 34: Level Control Labels: 3D0-907-553-V1.clb
Part No: 3W0 907 553
Component: LUFTFDR.-CDC- 3C1V0 7014
Coding: 0015500
VCID: F7FD8D5785381FA6259-5072
Address 36: Seat Mem. Drvr Labels: None
Part No: 3W0 959 760 A
Component: CM Seat Driver 0008
Coding: 0000002
Shop #: WSC 07360 106 74048
VCID: 3F8DA5776D8867E6AD9-5072
4 Faults Found:
00997 - Motor for Driver's Seat Position; Fore/Aft (V48)
005 - No or Incorrect Basic Setting / Adaptation
01174 - Driver Seat Height Adjustment Motor (V138)
00998 - Motor for Driver's Seat Recline (V45)
01903 - Seat Tilt Adjustment Motor (V231)
Address 37: Navigation Labels: None
Part No: 3W0 919 887
Component: NAVIGATION 0168
Coding: 0400000
VCID: 04076A9B44EEC43EB0B-50E6
1 Fault Found:
00862 - Antenna for GPS Navigation (R50/R52)
012 - Electrical Fault in Circuit
Address 38: Roof Electronics Labels: None
Part No: 3W0 907 135 C
Component: Dachmodul 0702
Coding: 0000157
VCID: 3663C05342B2A6AE7EF-5072
Address 46: Central Conv. Labels: 3D0-959-933.lbl
Part No: 3D0 959 933 F
Component: 1G HSG 0100
Coding: 0000032
VCID: 3365F94751C0B386591
Subsystem 1 - Part No: 3W1 959 701
Component: Tuersteuergeraet FS 0702
Subsystem 2 - Part No: 3W1 959 702
Component: Tuersteuergeraet BF 0702
Subsystem 3 - Component: TSG HL No Answer
Subsystem 4 - Component: TSG HR No Answer
Subsystem 5 - Part No: 7L0 907 719
Component: Neigungssensor 0020
Address 47: Sound System Labels: 7Lx-035-4xx-47.lbl
Part No: 3W0 035 456 B
Component: 12K-AUDIOVERST 4120
Shop #: WSC 00000 000 00000
VCID: 3365F94751C0B386591-5072
Address 53: Parking Brake Labels: 3W0-907-801.clb
Part No SW: 3W0 907 801 B HW: 3W0 907 801 B
Component: EPB BC6HX23 HC6 X230
Coding: 0022413
VCID: 3561C75F5FB4ADB6775-5072
Address 57: TV Tuner Labels: 3D0-919-146.lbl
Part No: 3D0 919 146
Component: TV Tuner H07 1205
Coding: 0000010
VCID: E5C1D71F2F949D36875-50E6
Address 68: Wiper Electr. Labels: 3Wx-955-023.clb
Part No: 3W1 955 023 C
Component: Wischermodul ª0323
Shop #: WSC 00000 725 65552
VCID: 3663C05342B2A6AE7EF-50E6
Address 71: Battery Charger Labels: 3D0-915-181.lbl
Part No: 3D0 915 181 B
Component: Batteriemanagement 2600
VCID: 224B0C03FE3A2A0EA27-5072
Address 76: Park Assist Labels: 3D0-919-283.lbl
Part No: 3W0 919 283
Component: 02 Einparkhilfe 0203
VCID: FAFB9463B62A02CE5A7-5072
Address 77: Telephone Labels: None
Part No: 3W0 035 729 C
Component: Telefon 0241
VCID: 377DCD5745B85FA6659-5072
End ---------------------------------------------------------------------
Coding: 0000173
1 Fault Found:
P1923 - 008 -
Coding: 0000101
Coding: 0007878
Coding: 0131309
Component: ELV XXXX
2 Faults Found:
Coding: 0000002
1 Fault Found:
Coding: 0400335
3 Faults Found:
Coding: 0000001
Coding: 0000105
Coding: 0000173
Coding: 0012360
Coding: 0000012
Coding: 0021100
Coding: 0000006
Coding: 0015500
Coding: 0000002
4 Faults Found:
Coding: 0400000
1 Fault Found:
Coding: 0000157
Coding: 0000032
Coding: 0022413
Coding: 0000010
Can anyone tell me where these modules are?
Hello @NoName ,
The rear window lift control modules (aka door control module) are located behind each side rear panels as pictured, they are both the lift motor and a control module in one, the TPMS control module (the small white box) is mounted on top of the suspension control module as pictured, being that you have the same faults for both rear windows and the TPMS in both the (05) KESSY module, and (07) the control head Infotainment unit, I would check that the drivers side (LHD) floor under the carpet is dry, and that the KESSY shows no signs of corrosion, as that is where the KESSY is located, then do the same to inspect both sides in the rear, the rear seats need to be removed, that is a simple 2 minute job each, the lower portion pops up and out, the rear portion is one torx bolt removal and out.
Let up know how these faults came to be, all at once, or over time, did you have any work whatsoever done to the vehicle prior to realizing that the rear windows stopped working ?
The issue may also stem from the master window control module which is the drivers door lift motor/cm module, but I would check the KESSY and the rear quarter areas for water leakage/corrosion first.
Johnny
Johnny
![](https://cimg2.ibsrv.net/gimg/www.6speedonline.com-vbulletin/2000x1143/screenshot_20240625_094522_chrome_60f643657fac3abc95c26d004ef31d641316e073.jpg)
![](https://cimg3.ibsrv.net/gimg/www.6speedonline.com-vbulletin/2000x995/screenshot_20240625_094753_chrome_cb48dcd4a785ecfe90932f38ea604489060cfd02.jpg)
![](https://cimg4.ibsrv.net/gimg/www.6speedonline.com-vbulletin/2000x943/screenshot_20240625_094812_chrome_e02d1aa76878e208031a8b8164bc0100c12650ce.jpg)
![](https://cimg9.ibsrv.net/gimg/www.6speedonline.com-vbulletin/2000x1149/screenshot_20240625_111951_gallery_fb8c63c2ad3f67e37add241afeccb5c7a6eeb258.jpg)
@Johnny Hotspur GT, Thank you! You are amazing library!
Honestly, I never used them or tested them when I bought conti a few years ago.
When I bought the car, the service center told me that there were no critical errors in the engine, gearbox, and suspension, and the body was in its original paint.
I know the rear spoiler didn't work when I bought it, that's a common problem.
I noticed the rear windows didn't work when I had a problem with noise from the shifter.
It's a bit scary to disassemble the interior =(
@NoName ,
Being that you have the GT, the rear quarter glass windows are supposed to drop between a 1/4 to 3/8 of an inch every time you open either door, just as your door glass drops when each time you open the door, does each door glass drop on the door being opened ?
It may be that your rear window regulators have failed, and instead of repairing or replacing them, someone just fixed the glass in the up position..
Do you hear any clicks at all in the rear when activating either rear window switch, or, any dimming of the interior lights when doing the same ?
Window regulator.
Johnny
Window regulator.
![](https://cimg8.ibsrv.net/gimg/www.6speedonline.com-vbulletin/1160x2000/20220706_212133_d0e1dd3a9835b48a035525e9d6a38b3905d5bb38.jpg)
![](https://cimg9.ibsrv.net/gimg/www.6speedonline.com-vbulletin/1120x2000/20220706_212149_8caf3db5589717ba0643daaf930dbc621d56f93c.jpg)
![](https://cimg0.ibsrv.net/gimg/www.6speedonline.com-vbulletin/1865x882/20220706_212220_85b2d9ca2123073a9a79128bd1c0ce7ce051c832.jpg)
Johnny
Johnny Hotspur GT No, nothing happens.
Only the front windows go down when I open the door.
The rear windows show no signs of life and no dimming lights.
sam08861
Bentley
61
03-03-2023 12:30 AM
