2006 Bentley Air Suspension Issue Help
Old 03-13-2024, 06:27 AM
mrc00l88's Avatar
mrc00l88 is infamous around these parts
We cannot get the Bentley to raise itself. Tried jacking up, placing wood under tires, etc. Replaced the '53' relay in the trunk. Nothing kicks on. Tried going in/out of jack mode using the 2 buttons center console, and VCDS - no luck. Relevant Fault codes below. Any ideas? Thank you
Address 34 - Level Control Module
Fault codes:
​​00668 - Supply voltage terminal 30
009 - Open or short to ground
01575 - Control switched off
000 --
00778 - Steering angle sensor (G85)
013 - Check DTC memory
Old 03-13-2024, 09:23 AM
Johnny Hotspur GT's Avatar
Administrator
Hello @mrc00l88 ,
I see that you replaced the relay, but did you check the 40 amp fuse for the air suspension compressor, it is located in the trunk as pictured below.
Did you take this scan while the vehicle was in jack mode, as the scan shows that the "control (is) switched off", therefore you may need to go into address 34 and then adaption (IIRC) to turn it on.
There are also two 10 amp fuses to check, one in the trunk to the right of the orange 40amp, it is the furthest to the right, third up from the bottom, the next to amp fuse is in the dash facia fuse box, it is the third one in from the left on the bottom row of the fuses.
Also check all mega fuses at the battery mounted pack, as your terminal 30 shows it to be open, or shorted to ground, if it was shorted to ground, you would have bigger issues.
Johnny
Old 03-13-2024, 11:26 AM
mrc00l88's Avatar
Thanks for the reply @Johnny Hotspur GT - I will check all the different fuses, and try another new relay.
----- I am unable to get out of 'jack mode' apparently.. neither using the two buttons (suspension/ride height) in the center console, nor in VCDS following these steps from http://wiki.ross-tech.com/wiki/index.php/01575 Level Control Address 34, [Adaptation] Channel [010], [Test] and [Save] a new value of [0]
Interestingly it seems to always have a '1' in the field, and a '1' value is supposedly 'active'? See screenshot attached when saving a '0' value, the yellow tip bubble popped up in the background.
Old 03-14-2024, 06:44 PM
mrc00l88's Avatar
@Johnny Hotspur GT 10amp fuse -- What is the blue hard (metal) line under the car on the right side (runs with a black line of the same kind) - fuel related?
Cheers
Old 03-14-2024, 07:02 PM
Chessey's Avatar
Chessey is infamous around these parts
Yes the blue line should be fuel vapor for the emissions systems
Old 03-14-2024, 08:07 PM
Administrator
Cheers
@mrc00l88 ,
Does that mean that the 10 amp fuse was blown, if so, what may have caused it to blow, is the suspension up and running ?
Johnny
Old 03-15-2024, 12:38 PM
mrc00l88's Avatar
@mrc00l88 ,
Johnny
Was blown, yes. Vehicle was delivered as such. All seems fine now, thanks !
Old 03-15-2024, 01:50 PM
Administrator
Great !
Glad to help.
Johnny
Old 03-17-2024, 11:22 PM
mrc00l88's Avatar
@Chessey @Johnny Hotspur GT
So, the complete blue line underneath the middle of the car more or less, has a connection point that joins two lines if I recall correctly.
I need the line that goes from the middle of the car up to the engine bay.
All I could find is part# 3D0201294F - but I think this part# might be the line from the middle of the car that goes back to the fuel tank area.
Either of you guys know if this is the part#, or what the correct part# might be?
Thank you
Old 03-18-2024, 01:08 AM
Administrator
@Johnny Hotspur GT
Thank you
@mrc00l88 ,
IIRC, the blue line is the fuel return line to the tank, the lines only come as a set, ranging from $700+/- to $1795.00.
I do not believe if you ever said this was a GT or FS.
Here are the lines in my GT passenger side wheel well, and up into the engine compartment, where they connect to the snap on hoses that run to and from the fuel rail.
Here are some screenshots from Scuderia for the 2004-06 GT fuel line set, part number 3W3 201 059 C, (15) on the diagram.
2007 is depicted as number 3 on the diagram.
This is where the supply and return hook up to at the fuel tank.
This is another diagram depicting number (3), for the FS.
EDIT:
I MAY HAVE FOULED UP MY PICTURE LAYOUT, BUT I AM GOING TO BED, IT'S 3:45 AM... 🥱
BE BACK LATER TODAY.
Johnny
Last edited by Johnny Hotspur GT; 03-18-2024 at 01:44 AM. Reason: Edit note about edit...
Old 04-03-2024, 02:48 AM
mrc00l88's Avatar
Thanks Johnny.
Do you/anyone happen to know the diameter of the fuel line itself, looks like perhaps a 3/8 line?
Have to repair a small section of tube under the car, and want to use the same type of steel line.
Thinking of using something like this connector (if 3/8 is the size of course): https://shop.advanceautoparts.com/p/dorman-high-pressure-compression-union-rated-for-5000-psi-3-8-in.-800-205/10600312-P
Cheers
Old 05-10-2024, 06:46 AM
mrc00l88's Avatar
Will a kinked blue fuel return/evap line cause any drivability or fueling (pump) issues?
How much fuel is sent through this line/is it constant or a minute flow?
Thank you
Old Today, 06:51 AM
sazam's Avatar
sazam has much to be proud ofsazam has much to be proud ofsazam has much to be proud ofsazam has much to be proud ofsazam has much to be proud ofsazam has much to be proud ofsazam has much to be proud ofsazam has much to be proud of
Hi,
what is the size (diameter) outer & inner of the suspension air lines?
Dubaitechie
Bentley
50
08-18-2023 06:06 PM
BENTELY POWER
Bentley
05-08-2023 03:51 AM
Bullsharks28
VW
08-02-2020 11:48 AM
Adesoji Orola
Bentley
03-04-2017 11:52 AM
Quick Reply: 2006 Bentley Air Suspension Issue Help
