13-18 BENTLEY Breitling Clock can id's
Any way to get the CAN ID's for this? I want to make a desk clock out of it but I need the CAN ID to set the time. It defaults to 12;00 when powered on and the backlight is can bus. or if anyone even knows the range i can try and sweep it.
That would work, but you'll be behind 30 seconds every day, which is less accurate than what quartz clock is capable of. (about +/- 15 seconds per month on average to as little as +/- 1 second/year)
I could do an ardino sync'd with NTP cut the power at 11:59:30 wait 15 secs power it back on about 10 15 secs for the hands to set it would stay in sync'd within a few secs. Would be cooler though if I could NTP sync with can bus and use the backlight tho
Got backlight and hour so far, still searching for Minute hex
back light ID 635 Hex 100 0 0 0 0 0 0 0
0-100 (off to full bright)
Time ID 623 HEX 0 2 0 0 0 0 0 0
X Hour 0-11 X X X X X X X
how did you get the can IDs if it's not a secret?
Thank you,
Marko
I had the same idea and came across this forum via Google.
It was a little bit of luck and a little bit of a needle in a hay stack. After finding the correct baud rate I got a can response from the click, like a Hi I'm here and awake. I took that CAN ID then built a script to increment each bit by 1. After like 45 secs I got a back light and movement. I slowed down the script and eventually was able to scrape the can ID"s
I used an Ardino canbed which has the esp and MCP2515 on 1 board - https://www.seeedstudio.com/CANBed-A...51-p-4365.html
Think this is the code I used, so it takes each bit starts it at 00 and increments by 1 to FF then moves to the 2nd bit and increments both then on to the 3rd, etc.
I have done alot of can projects so quite familiar with CAN bus and esp 32's
Hope that helps
Hope that helps
This is for use with Sparkfun's CAN Bus Shield: https://www.sparkfun.com/products/10039
#include<Canbus.h>
#include<defaults.h>
#include<global.h>
#include<mcp2515.h>
#include<mcp2515_defs.h>
voidsetup(){
Serial.begin(115200);
Serial.println("CAN Write - Testing transmission of CAN Bus messages");
delay(1000);
if(Canbus.init(CANSPEED_125)) //Initialise MCP2515 CAN controller at the specified speed
Serial.println("CAN Init ok");
else
Serial.println("Can't init CAN");
delay(1000);
int x = 0xFF;
int b = 0xFF;
voidloop()
tCAN message;
x++; // now x is 0xFB
b = b + 1;
// message.id = 0x6B2; //formatted in HEX
message.id = x, HEX; //formatted in HEX
message.header.rtr = 0;
message.header.length = 8; //formatted in DEC
message.data[0] = b;
message.data[1] = b;
message.data[2] = b;
message.data[3] = b; //formatted in HEX
message.data[4] = b;
message.data[5] = b;
message.data[6] = b;
message.data[7] = b;
//message.data[5] = message.data[6] +1;
// message.data[6] = message.data[6] +1;
// message.data[7] = message.data[7] +1;
// message.data[0]++;
mcp2515_bit_modify(CANCTRL, (1<<REQOP2)|(1<<REQOP1)|(1<<REQOP0), 0);
mcp2515_send_message(&message);
Serial.print("ID");
Serial.print(" ");
Serial.print(message.id, HEX);
Serial.print(" ");
Serial.print("HEX");
Serial.print(" ");
Serial.print(message.data[0], HEX);
Serial.print(" ");
Serial.print(message.data[1], HEX);
Serial.print(" ");
Serial.print(message.data[2], HEX);
Serial.print(" ");
Serial.print(message.data[3], HEX);
Serial.print(" ");
Serial.print(message.data[4], HEX);
Serial.print(" ");
Serial.print(message.data[5], HEX);
Serial.print(" ");
Serial.print(message.data[6], HEX);
Serial.print(" ");
Serial.print(message.data[7], HEX);
Serial.println("");
delay(100);
#include<Canbus.h>
#include<global.h>
#include<mcp2515.h>
voidsetup(){
delay(1000);
else
delay(1000);
int x = 0xFF;
int b = 0xFF;
voidloop()
tCAN message;
b = b + 1;
Serial.print("ID");
Serial.print(" ");
Serial.print(" ");
Serial.print(" ");
Serial.print(" ");
Serial.print(" ");
Serial.print(" ");
Serial.print(" ");
Serial.print(" ");
Serial.print(" ");
Serial.print(" ");
Serial.println("");
delay(100);
