How often & how frequently should I check my V8V coolant?
Old 06-18-2024, 09:07 AM
sweet991S's Avatar
sweet991S is infamous around these parts
Even tho' my car only 20K on the clock, it's 14 years old......any thoughts gents? No, it's not running hot but it's a big V8 and in Virginia summers, it WILL get warm in the E compartment!
Thanks in advance.
Old 06-18-2024, 09:23 AM
embdenb's Avatar
embdenb is a splendid one to beholdembdenb is a splendid one to beholdembdenb is a splendid one to beholdembdenb is a splendid one to beholdembdenb is a splendid one to beholdembdenb is a splendid one to beholdembdenb is a splendid one to beholdembdenb is a splendid one to behold
I have never checked my coolant level. Maybe I should.
Old 06-18-2024, 09:24 AM
sweet991S's Avatar
Ha - maybe you should.. Thnks embrend
Old 06-18-2024, 09:28 AM
V12Vin's Avatar
V12Vin is infamous around these parts
Check as in level/leaks or effectiveness? I check my level every 2 to 3 months, effectiveness every year. Change once every 4 to 5 years.
Old 06-18-2024, 09:30 AM
sweet991S's Avatar
Greatly appreciate that - Redpants' Maintenance Guide (I just read it a sec ago) - sez the same thing. Mine is therefore overdue for drain/refill.....
Old 06-18-2024, 10:28 AM
Argus's Avatar
Argus is infamous around these parts
Change the coolant for piece of mind and for the car.
Old 06-18-2024, 11:22 AM
sweet991S's Avatar
Argus -- yes, you are right, and this fall when I do the oil, I will also get that done.
Thank you!
Old 06-18-2024, 11:55 AM
embdenb's Avatar
I do change mine every five years at the dealer (Smile)
Old 06-18-2024, 04:29 PM
sweet991S's Avatar
LoL.....
Old 06-18-2024, 04:51 PM
GA_DB9's Avatar
GA_DB9 Is a GOD !GA_DB9 Is a GOD !GA_DB9 Is a GOD !GA_DB9 Is a GOD !GA_DB9 Is a GOD !GA_DB9 Is a GOD !GA_DB9 Is a GOD !GA_DB9 Is a GOD !GA_DB9 Is a GOD !GA_DB9 Is a GOD !GA_DB9 Is a GOD !
There are corrosion protectants in antifreeze that are consumed with age. After about 12 years my Mercedes M272 engine developed a small leak at the water pump. At the point of the leak where the coolant was able to react with air there was a large amount of pitting on the aluminum sealing surface of the pump and timing cover. It seemed like the ancient coolant became corrosive to aluminum at some point. Luckily a little RTV added to the factory gasket sealed it up, but it sure did teach me a lesson.
Stick with the recommended refresh interval and keep an eye out for leaks.
Old 06-18-2024, 05:07 PM
HabitualOffender's Avatar
HabitualOffender is a name known to allHabitualOffender is a name known to allHabitualOffender is a name known to allHabitualOffender is a name known to allHabitualOffender is a name known to allHabitualOffender is a name known to all
There's a low coolant sensor, when it gets down about 2" in the overflow tank it come on and tells you long before you need to worry about it. But, if it's never been drained it should be.
Old 06-18-2024, 05:09 PM
sweet991S's Avatar
Thanks to you both. New info to me. Cheers, TC
Old 06-23-2024, 06:11 AM
brightoncorgi's Avatar
brightoncorgi has a reputation beyond reputebrightoncorgi has a reputation beyond reputebrightoncorgi has a reputation beyond reputebrightoncorgi has a reputation beyond reputebrightoncorgi has a reputation beyond reputebrightoncorgi has a reputation beyond reputebrightoncorgi has a reputation beyond reputebrightoncorgi has a reputation beyond reputebrightoncorgi has a reputation beyond reputebrightoncorgi has a reputation beyond reputebrightoncorgi has a reputation beyond repute
The coolant should be replaced every two or three years, no?
Old 06-23-2024, 12:09 PM
That's the 50,000 mile service, or every 5 years.
Info - Maintenance Guide — Redpants
Old 06-24-2024, 12:18 PM
V12Vin's Avatar
Or this. https://www.hrowen.co.uk/aston-marti...ice-servicing/
HRO is a respectable AM dealer in the UK. More comprehensive schedule including new models and quite frankly, prices are good even with the USD conversion and including VAT!
Here's a snippet for the model mentioned in this thread.
Quick Reply: How often & how frequently should I check my V8V coolant?
