Source for O-Rings for wing pump OR a used pump anyone?
Old 08-26-2024, 07:02 AM
TexasNewfie's Avatar
TexasNewfie has a spectacular aura aboutTexasNewfie has a spectacular aura aboutTexasNewfie has a spectacular aura about
Hi All, After 5 years without leaks in my rebuilt wing pump, I have a problem. Woke up to find pentosin seeping down the deck lid. Disassembly of the pump showed one of the black o-rings on the cylinder piston was broken. its an odd shaped o-ring, somewhere between a standard round o-ring and what looks to be a square-edged o-ring, in that its sides look somewhat flat from design rather than just pure compression. I tried some viton o-rings I have here and they fit but they are smaller in thickness and required 2 to fill the space requiring me to remove the white spacer next to the OEM o-ring. In the end, there is still a leak and this odd sized o-ring doesn't seem to be generally available where I've searched.
I've decided this is my last ditch attempt to either rebuild the wing pump or purchase a used pump in working (i.e. non-leaking) condition if someone has one. If not, I'll go to the 3" eRam kit, which seems a great alternative with positive reviews and good support. Glad to see there is this option.
Old 08-27-2024, 05:29 AM
DaveCarrera4S's Avatar
DaveCarrera4S has a reputation beyond reputeDaveCarrera4S has a reputation beyond reputeDaveCarrera4S has a reputation beyond reputeDaveCarrera4S has a reputation beyond reputeDaveCarrera4S has a reputation beyond reputeDaveCarrera4S has a reputation beyond reputeDaveCarrera4S has a reputation beyond reputeDaveCarrera4S has a reputation beyond reputeDaveCarrera4S has a reputation beyond reputeDaveCarrera4S has a reputation beyond reputeDaveCarrera4S has a reputation beyond repute
Fix it permanently by upgrading to the eRam system from Rennkit, or check eBay for used hydraulics. There is normally a few units for sale.
Old 08-29-2024, 08:15 AM
mxracer's Avatar
mxracer has a reputation beyond reputemxracer has a reputation beyond reputemxracer has a reputation beyond reputemxracer has a reputation beyond reputemxracer has a reputation beyond reputemxracer has a reputation beyond reputemxracer has a reputation beyond reputemxracer has a reputation beyond reputemxracer has a reputation beyond reputemxracer has a reputation beyond reputemxracer has a reputation beyond repute
Take them to a hydraulics shop to match up. They are not actually o-rings they are hydraulic seals. You can also measure them and search online as well if you are so inclined.
Old 08-30-2024, 06:18 AM
jpflip's Avatar
Long time ago, I went to an o-ring company here in Montreal with all the used o-rings that came out from the spoiler sytem. Here a picture I took of what they give me as alternate : Of course they are Viton o-rings....
Old 08-31-2024, 08:21 AM
@jpflip Did these work for you? Rebuilt with no leaks?
I'm still considering the eRAMs though. Tired of messing with pentosin and this thing in general.
Old 08-31-2024, 08:22 AM
@DaveCarrera4S The eRAMs look to be a really elegant solution. Nicely done. Definitely considering
Old 08-31-2024, 09:01 AM
jpflip's Avatar
The motor parts yes but I did not feel confident with my modification I did on the two actuators....Finally decided to send everything to Belgium for a full overhaul...Really satisfied with the works of Harald at DH automotive... It was important for me to keep the system original....
Old 09-01-2024, 02:22 PM
Don’t forget the discount code, 6Speed5off for a new set of eRams at http://Rennkit.com
Old 09-10-2024, 01:45 AM
LucyColeman's Avatar
LucyColeman
Thank you so much for the link.
hollywood996tts
03-18-2019 12:18 PM
Steve Jarvis
04-21-2014 09:15 PM
Steve Jarvis
08-14-2012 10:23 PM
1BadBlue930
03-14-2012 06:47 AM
Quick Reply: Source for O-Rings for wing pump OR a used pump anyone?
