Sportshift gearbox oil change
Old 08-29-2024, 12:01 PM
The_Orange's Avatar
The_Orange is infamous around these parts
Hello all, my English isn't the best and i'm lookin at old threads about the transmission oil and now i'm even more confused.
I have a 2008 Vantage Sportshift 1 and a friend of mine, a retired mechanic, is going to do the service. He has done the standard engine oil and filters change, bypass filters and air filters in the past, so no problems there.
However, the gear oil has to be changed as well, and this is where i'm confused:
An old thread said that there are 2 seperate systems: the ASM oil and the transaxle oil. The ASM can't be changed without having access to AMDS, but the transaxle oil shouldn't be a problem. Is this correct?
My second question is: which is the one that should be changed every 4 years? Is it the Transaxle oil (castrol BTO) or the sportshift oil (Pentosin CHF 11S)? Or should they be changed both every 4 years? Someone in that old thread suggested that only 1 needed to be changed every 4 years and the other one shouldn't be changed because the clutch wears out before the fluid can build up too much humidity.
TLDR: which is the oil that should be changed ideally every 4 years: the castrol BTO 270A or the Pentosin CHF 11S
Thanks in advance!
Old 08-29-2024, 01:17 PM
Phil57DBS's Avatar
Phil57DBS is infamous around these parts
Castrol BOT270A
equivalent Redline MT-LV 70w75
Old 08-29-2024, 01:28 PM
The_Orange's Avatar
Originally Posted by Phil57DBS
Castrol BOT270A
Thanks!
If i'm not mistaken, this is the transaxle oil. Is this the one that is the DIY? I mean, this can be done without having access to a AMDS?
Old 08-29-2024, 03:34 PM
ragingfool35's Avatar
ragingfool35 is infamous around these parts
they are all DIY. the hydraulic fluid is a little more involved but can be done without AMDS for your model year (there is a recent thread where someone just did it https://www.6speedonline.com/forums/...leeding-2.html). the BOT270A is as easy as it gets. see the Redpants instructions or video. you need the socket and allen socket for 1/2" drive and a pump
Amazon Amazon
ScottDy
02-04-2021 08:48 AM
Quang
11-19-2020 06:53 PM
I'mAllIn
06-18-2013 08:41 PM
macksamus
03-21-2012 01:29 PM
ar2ro1
10-21-2006 01:47 PM
Quick Reply: Sportshift gearbox oil change
