Higher revs on Park
Old 09-09-2024, 02:27 AM
chrzesm's Avatar
chrzesm is infamous around these parts
Higher revs on Park
AM11 engine with ZF6HP26 gearbox (vanquish 2013 with low mileage 16k miles) is revving higher (750rpm) on Park. On Drive it goes calmly 650rpm. The engine gets rough idle when cold on Park.
Any suggestions very welcome.
Thank you and all the best to everyone!
Old 09-09-2024, 06:30 AM
J doubleU's Avatar
Have you had it scanned for codes? 100 RPM difference is very normal from park to drive or reverse. If you are feeling a misfire at idle regardless of gear selection you most likely need ignition coils replaced. After 11 years of service it should have had spark plugs replaced at the 7 year maintenance. If not they should be replaced with the coils. Have it checked for possible codes stored first.
Old 09-09-2024, 06:41 AM
chrzesm's Avatar
Thank you so much for your input. AMDS shows no DTC. All coils, plugs and injectors replaced for OEM new sets just month ago. I suspected throttles need cleaning.
Just an amateur's question. I am trying to understand why RPM is higher on Park vs Drive with foot on brake, in both cases rpm of the gear box shaft should be zero, so converter is loaded the same way?
hamlmarzooqi
06-24-2013 07:43 PM
VIPNiSS
Cayenne 955/957
01-02-2013 03:55 AM
Sam996TTS
09-12-2011 03:36 PM
dksu
02-26-2010 06:22 PM
Quick Reply: Higher revs on Park
