AM radio is dead…
Old 09-15-2024, 01:35 PM
Argus's Avatar
Argus has a spectacular aura aboutArgus has a spectacular aura about
AM radio is dead…
I have a USA 2007 Vantage with a manual transmission. The AM radio band is dead. I know the radio is a Volvo/Alpine unit and a common problem. I understand the was a TSB issued but I can’t find it anywhere on the net. Trying to get an answer from an AM dealer is impossible. I have the Vehicle Build Specifications for my car. I have found aTSB for Volvo related to the AM radio. But I can’t seem to find out if there is an anti-theft code for the radio and what happens if I disconnect the AM radio module? I don’t know what this means from the build sheet ; AM / FM HARNESS: AM/FM Non TMC Harness (HN00). In the US there is a radio repair company that can repair any car for around $100 USD. But I don’t know what will happen if I remove the module will the radio not work again thinking the radio has been stolen? The owners manual does not say anything about a security code.
Any and all information would be great.
Old 09-15-2024, 07:07 PM
J doubleU's Avatar
If you remove the AM/FM module nothing will work. If they can repair it then there's no issue with theft or coding of it. Basically a plug n play module that does have to be connected to the MOST network for everything else to play nicely.
Old 09-15-2024, 10:34 PM
GA_DB9's Avatar
GA_DB9 Is a GOD !GA_DB9 Is a GOD !GA_DB9 Is a GOD !GA_DB9 Is a GOD !GA_DB9 Is a GOD !GA_DB9 Is a GOD !GA_DB9 Is a GOD !GA_DB9 Is a GOD !GA_DB9 Is a GOD !GA_DB9 Is a GOD !GA_DB9 Is a GOD !
MOST bus anti-theft should be disabled on Fed spec Astons. I know mine is for sure. The radio tuner module is a Volvo unit and should swap out without any issues. Volvo 30732565 for example looks identical to the Aston AM/FM tuner.
Old 09-16-2024, 01:42 PM
Argus's Avatar
Ok here is an update on the radio repair. I talked with United Radio today at length and they say they can not repair the radio. They can not even find the Alpine unit in their vast system. Their suggestion was to try to fine the information on Volvo websites which I had already done. This is a very common problem but without much remedy.
Old 09-16-2024, 03:27 PM
GA_DB9's Avatar
Not surprising. There shouldn't be anything "Alpine" to repair with respect to the radio tuner module. The tuner is a separate module on the MOST bus. It is accessible above the right rear wheel arch behind the wheel arch liner. It may be Aston Martin branded, but it's a Volvo module. I've had mine apart, disconnected, and reconnected on my DB9 without issue when I installed the factory Sirius module a while back.
Later models (2009+) look to have the am/fm tuner integrated into the CD changer, but for 07 it's separate.
Old 09-16-2024, 07:19 PM
Viper98912's Avatar
Viper98912 has a spectacular aura aboutViper98912 has a spectacular aura about
What's "AM" radio?
Perhaps this is a sign...
Argus
11-09-2021 08:54 AM
broncoupe
01-05-2020 08:44 AM
bobolouie
05-15-2013 01:41 PM
zambono
11-09-2009 07:57 AM
SpeedDemon
Cayenne 955/957
01-31-2007 03:12 PM
Quick Reply: AM radio is dead…
