997.2 Drive Belt Replacement Issue
Has anyone had an issue with the 16mm engine carrier bolt not lining up exactly with the access hole through the rear bumper? The bolt is about 2 mm lower than center making it impossible to get a socket on it. I could raise the engine slightly, but I'm not sure this is the best way to solve the problem. Any suggestions?
rcgalore
01-11-2014 03:22 PM
