Long cranking, high pressure fuel pump?
Old Today, 01:13 PM
lp2885's Avatar
lp2885
Hey everyone, quick question regarding fuel pressure on a cold engine. On Cayenne base 3.6, when the ignition is on but the engine isn't started, should the high-pressure fuel pump pressure be the same as the low-pressure fuel pump?
I'm experiencing long cranking only on a cold engine, and I suspect the HPFP is failing. Sometimes the engine starts after long cranking but immediately turns off. However, if I try starting it again, it starts right away. No codes.
dynamic101
Cayenne 958
05-06-2017 12:02 PM
LQQK
07-23-2012 07:49 PM
jcam
05-05-2012 08:41 AM
Dharn55
06-16-2009 09:23 PM
adias
Cayenne 955/957
02-05-2009 08:14 PM
Quick Reply: Long cranking, high pressure fuel pump?
