2007 AM Vantage, high can issue, car will not start
Hi guys,
This is a 2007 AM Vantage with a High CAN and Low CAN issue so I couldn´t start the car. The car had an small accident and now I´m rebuilding it.
I have an original AMDS System for better testing. I did all the testings regarding Canbus, checked resistance (60 ohms), tested short circuit
to ground and to power. DIM is not working, I only could see the engine light. Swapped the DIM, no change. Checked +/- on the DIM plug, checked
short to +/-, nothing. Could access every module by AMDS except DIM, tested with an oscilloscope the Canbus, voltage and communication seems okay for both circuits.
swapped the BCM, nothing.
Does anybody of you guys have an idear what I could do next ?
Thanks to all
Thanks to all
Are you sure your CEM works ok? It should send CAN messages waking up the DIM. Do you have CAN analyser to see if the CEM sends anything to DIM? DIM can be initiated with CEM frames on Low Speed CAN: EC353BC 01 00 00 00 BD 8E FF 7A or EC353BC 01 00 00 00 BD 98 00 85. I would check if you see CAN signals directly on DIM socket, it seems to me you have CAN lines broken between DIM and CEM. To start the engine DIM should send matching VIN, otherwise ECM will not crank.
Hi V12AM,
I was measuring on the OBD port and I used the chassis of the vehicle as ground. Furthermore I have tested CAN BUS communication with an simple OBD testing tool (CTB007)
I have measured HI CAN and LOW CAN on the same time.
Hi,
furthermore I have the error "fuel system disabled", might have something to do because of the DIM issue.
What I did in the meanwhile:
Checked the fuel pump: OK
Checked the fuel pressure (in range): OK
Checked the fuel ECU, behind subwoofer, driver seat: OK
Checked the pyro fuse: OK
Had a strange issue when I disconnected the "INFOTAINMENT CONTROL MODULE" (behind center dashboard) after I turned on the ignition some modules came back online.
But I couldn´t replicate this behaviour, maybe it was just a bug from the software, I don´t know.
P1233 - The fuel pump driver module is offline. There's a fuel pump monitor signal from the pump driver to the PCM. Either the fuel pump driver module is not getting power or the monitor signal is not getting back to the PCM.
The DIM lives on and terminates the end of both LS and HS CAN bus. Pin 2/3 is the low speed canbus. The other end is terminated by the airbag module. Pin 4/5 is the high speed canbus. The other end is terminated by the ABS module.
I would suggest to check if you can see CAN waives between pin 2 and 3 on the green plug. The DIM should wake up as soon as it has power supply and proper Low CAN communication with CEM. Engine MIL light is completely isolated and powered from ECM, so it does not say if DIM is properly powered. So you should see: GND - pin 30, +12V - pin 1, CAN signal - pins 2, 3.
Hi,
It is quite rare case. Check the wiring first. If the wiring is ok, I would just plug in CEM from any other Aston (w/o reflashing) and if DIM is alive, your CEM needs to be a) reflashed to your VIN, and if it does not help b) replaced. Are you sure the CEM is original one, ie no-one just pluged in a volvo flashed part taking out the original Aston programmed unit? Can you share the CEM numbers (printed on the case, not a label)?
Sorry, I just realised your CEM is visible by AMDS, and I assume when you start the diagnostic session the ECM's VIN matches with CEM VINs, otherwise you will receive a warning message. So for sure you have an original CEM in your car.
Please remember not to try to start the engine if you plug other car's DIM or CEM, otherwise your mileage will be compromised. You can have an ignition on, however do not crank the engine before you reflash DIM or CEM for your VIN.
