How do I Fish the Wire from the Fuse Box to the Overhead Console for my V1?
Wiring my V-1...
How did you guys get the wire from the fuse box to the A-pillar?
Need to go around the dash and A/C vent? Behind?
I think I can tuck it under the A-pillar then to the headliner once I get there.
Did you just end at the headliner? Or go into the overhead light area?
I used a 3 foot zip tie (worked great). Then I ran it down the weater strip on the passenger door, along the bottom of the glove box to the center console. I think I'll ground it to the sun roof motor. Good Luck.
Wiring my V-1...
what i did for my cousin was from the fuse box. run the cable inside the weather strip upto the roof then tucked the cable in the roof all the way to where he wanted his radar detector mounted. in your case you can pop out the overhead console and zip tie it there so there are not loose cables flapping around
Spatula also works good, personally I would just wire it to the sunroof wiring behind the switch in the ceiling. Very easy to do.
adnanm3
11-22-2023 03:43 AM
WheelB
991 Turbo Vendor Classifieds
07-23-2018 10:37 PM
proTUNING Freaks
09-15-2015 08:28 AM
