Tech / How To
Installing vinyls on your car.
Old 05-04-2009 | 09:28 AM
porsched4ed's Avatar
porsched4ed has much to be proud ofporsched4ed has much to be proud ofporsched4ed has much to be proud ofporsched4ed has much to be proud ofporsched4ed has much to be proud ofporsched4ed has much to be proud ofporsched4ed has much to be proud ofporsched4ed has much to be proud ofporsched4ed has much to be proud of
My car has been in several magazines, television, websites, etc. I like to change the vinyls every now and then. here is a basic explanation on how to install vinyls to your car.
Difficulty level: depends on vinyl design
Tools needed:
heat gun
spray bottle
Johnson's baby soap
distilled water
70% rubbing alcohol bottle
squeegee
exact o knife
shammy
an extra pair of hands
a garage or cool shaded area
Mix water and alcohol 70/40 (70% water, 40% alcohol) in the spray bottle.
Add one tablespoon of johnson's baby soap and mix well.
spray the area of application on your car, spray the back of the vinyl you are peeling generously.
apply the vinyl onto the car, the solution allows you to move it around until it is in the correct place.
use the squeegee and in one direction apply pressure to the vinyl.
use the heat gun to dry the vinyl on a medium setting.
begin to peel back the transfer tape, for intricate graphics, tear the transfer tape in strips, like cheap toilet paper tears
use the heat gun if it begins to lift to dry any solution, do not overheat it will damage the vinyls.
this takes patience, if the vinyls lift, pull the transfer tape off as you hold down the vinyls with the squeegee.
you may have to wait and allow the heat from the heat gun evaporate the moisture.
be patient. on breaks of the car, use the exact o knife and cut down the middle of the vinyls. briefly use the heat gun to help the edges be more sticky. this helps to curl the vinyl around edges.
repeat these steps for the rest of the vinyls, this was the most difficult part.
after the vinyls have been on the car for at least an hour, hose your car off on the light mist setting so that there is not alot of pressure on the vinyls. The soap will all run off
Old 05-10-2009 | 03:07 PM
tonyguy's Avatar
tonyguy is infamous around these parts
nice graphics. Looks like a tattoo.
Old 05-12-2009 | 03:48 PM
justingodfrey's Avatar
justingodfrey is infamous around these parts
nice write-up. on a graphic with less cutouts (more vinyl), you can also use a needle and poke a small hole in any "air bubbles" and use the heat gun to evaporate them out...then squeegee
COBB Tuning
01-29-2022 10:42 AM
Name Brand
11-21-2015 07:06 PM
The_Ruski_Driver
10-25-2015 09:40 PM
MadWhip
09-03-2015 03:04 PM
Quick Reply: Installing vinyls on your car.
