Dension IceLink Install (MOST Porsche)
If you have PCM put it in the trunk, if not you'll want the ipod in the car as it's almost impossible to navigate from the head unit and there is no usable track display.
If you're using PCM you can browse artists and tracks I believe and have full navigation, on a non-PCM (CDR23, CDR24) you have no display to speak of so at best you see "Folder 1", "Folder 2". If you have the iPod in reach you can navigate everything from that instead.
OK I have 2004 996tt with nav. I do not have a CD changer. I did take a close look at the amplifier and noticed that it does have the fiber optics going into it. So my question is, can I just connect the Dension unit to the amplifier rather than the head unit?
If so this will make my installation much easier. I was planning on leaving the Dension unit in the trunk and buying the ipod extension so that I can have the ipod in the glove box or rear center console. I don't think the ipod will like the intense heat of the summers in the trunk.
You mention "buying the ipod extension" - are you sure there is such a thing? I installed my Dension behind the head unit because (having a CDR23) I needed the ipod in the car and I couldn't find an ipid extension cable anywhere.
Just a quick update. I installed my Dension unit tapping into the fiberoptics directly from the amp and it works great. No need to remove the headunit. Everything was done in the trunk. Very easy.
If I get an IPOD extension cable from bumper plugs will I be able to navigate using the IPOD from the driver's seat?
I have cdr23 too and the installer set it up so the IPOD connects in the glovebox... this makes it hard to navigate the tracks as I can't physically reach the IPOD...
