Helmets: open or closed?
I know! It's counter-intuitave at first, but after you think about it makes sense. Like you, I want the protection of a full helmet but surely the SCCA knows more than me. I guess I'll go open faced...or break down and get the harness. I hate to put one in my street car. I need the back seat for my daughter, so would have to figure out how to mount one without having a harness bar.
Originally Posted by heavychevy
I think the closed face can help noobs keep from watching 10 feet in front of them. Open helmets are so freaking ugly it drives me nuts.
Is this SCCA recommendation online somewhere? If you can direct me, I would greatly appreciate it. Be nice to see all the reasoning behind that recommendation, if they provide it.
Originally Posted by msb2tg996
open face, specially with an airbag, scca recommends open face as well, just my .02 cents,
Found this, from November 2004:
http://www.mohud-scca.org/Info/downl...20Advisory.pdf
and this:
http://www.c2motorsport.net/helmets.html
and this:
Good job Doc, and thanks for the informative read. The upwards force of the lower section of the helment into the mandible certainly begs for a fracture, or at least, compression of the retro-discal tissue and/or TMD.
Perhaps those of us running Gt3 seats, 6-point harnesses, and HANS devices should talk to our tuners about a selective disconnect for the steering wheel airbag for race days. Certainly there can be some clever way to fool the ECU part of the time.
Thanks,
Al
Thanks,
Al
and this:
and this:
Thanks,
Al
Thanks,
Al
Perhaps if the harness is tight enough, you will not need to disconnect or remove the airbag at all. Also consider how forward you have your seat.
Otherwise, just remove the airbag on track days and replace it after the event. It's a simple procedure. You can disconnect the battery for a few minutes to reset the airbag light on the dash if you do not have an OBDII reset tool or scanner.
Aren't you supposed to wear a HANS device when wearing a helmet anyway (since the added weight can break your neck in a hard impact)? With a HANS on, I can't see how the airbag would cause your neck to move beyond its limits.
