SoCal racers - track times...
#46
EDIT: Summarized my posted times into one earlier post of this same thread:
https://www.6speedonline.com/forums/track-autocross/90477-socal-racers-track-times-2.html#post2319594
#47
'04 GT3:
05/09: SOWS cw: 1:32.6 [0]
06/09: laguna 1:50.7 [0]
07/09: laguna 1:45.15 [0,1]
09/09: buttonwillow #1 cw: 2:21.3 [0,1]
11/09: infineon: 1:58.8 [0,1]
1/30/10: buttonwillow #13 cw (first day): 2:11.3 [0-2]
5/3/10: buttonwillow #1 cw: 2:15.20 [0-3]
5/4/10: buttonwillow #1 ccw: 2:19.58 [0-3]
5/4/10: buttonwillow #1 ccw: 2:14.65 [0-4]
[0] mods:
3313 lbs
no cats
4 pt rollcage
corner balanced
camber -2.8/-2
ps2's
sway bars: 1 from full hard front and back
[1] mods:
carbotech xp10
[2] mods:
sparco evo's
6pt harness
stock lsd rebuilt w/guards internals(50/80, 75lbs preload)
[3] mods:
full floating ap racing front rotors: 360 mm
front pads: pagid r29 yellows
[4] mods:
fresh nt01: f 245, r 315
sway bars:
r: full soft
f: 1 from full soft
[0] mods:
3313 lbs
no cats
4 pt rollcage
corner balanced
camber -2.8/-2
ps2's
[1] mods:
carbotech xp10
[2] mods:
sparco evo's
6pt harness
[3] mods:
[4] mods:
sway bars:
r: full soft
f: 1 from full soft
#49
If you can run a 1:49 at ACSW Roval & 1:29 at Big Willow on street tires.. then you need to join alms.
Im going to need video to back these up, seeing is believing.
sorry not biting.
sorry not biting.
+1
EDIT: Added new times (not only Socal but SW region).
* SoW CW
1:21.8 996 Turbo 2WD (w/o ABS) on Hankook street tires Ventus RS2 315 rear and Ventus RS3 245 front
Buttonwillow CW13 (incl "bus stop" config)
* 1:55.7 996 Turbo RWD (KW V3, Carbonetic diff, 473 crank hp), Hankook street tires Ventus RS2 315 rear and Ventus RS3 265 front
* 2:00.5 996 Turbo with PSS9 on skinny 225/40/18 & 285/30/18 Yokohama A048.
* 2:03 in a stock 2003 350Z, 3700lbs (used Hankook C91)
* 2:04 testdriving a friend's Honda S2K on Federal RSR street tires with a slipping clutch, he has coil-overs and aero.
Cali Speedway Infield (Speed Ventures events)
* 1:11.5 996 Turbo with PSS9 on used Yokohama Advan Neova fronts and used R888 rears
* 1:19 2006 Nissan 350Z on OEM runflats and auto transmission
Cali Speedway Roval (oval and infield)
* 1:49.2 996 Turbo with PSS9 on Hankook street tires Ventus RS2 315 rear and Ventus RS3 245 front
* 1:47.x Nissan 350Z Formula D car on Hankook RS3
* Las Vegas Motor Speedway Outside Road Course (cw) with "sweeper" turn 1&2 instead of full length)
1:45.8 996 Turbo RWD (KW V3, Carbonetic diff, 473 crank hp), Hankook Ventus street tires
* Willow Springs Intl Speedway (Big Willow)
1:29.3 2003 Nissan 350Z TT drift car (9 psi boost = appr 415 crank) 3205 lbs incl driver, coilovers and aero, Hankook street tires Ventus RS3 265 front 285 rear
* SoW CW
#50
Laptimes on those particular events are set within the regulations and official timing of Redline Time Attack. Tires were checked by officials after 3 hot laps, they were RS2/3 Hankooks which is an agressive street tire but not an R-comp like R888 or Hoosier.
Big Willow 1.29 I ran with a Formula Drift car which imo is a touch slower than my white wrapped 996TT 2WD in the avatar was. I unfortunately never got a chance to run my 02 996TT in "finished" spec.
On a sidenote, I have instructed at least 1 ALMS driver (who raced a GT3 Cup car this last season) and raced door to door with at least Acura's ALMS drivers less than a month ago in the 25H of Thunderhill.
#53
Here are some street car times from last year for reference. All times are official from Zone 8 PCA TT series:
98 Boxster 2.5L BSX car, essentially stock w/full interior and climate control on NT-01 tires. 2962 lbs official weight w/driver and 1/4 tank fuel.
SOW- CW 1:29.4
WSIR- CW 1:40.2
Spring Mtn 3.1 CW 2:48
Autoclub Fontana Roval CCW 2:01.03
Auto Club Fontana infield CW 1:18.3 (hot)
Buttonwillow Config.#1 CW 2:15.6
SOW- CW 1:29.4
WSIR- CW 1:40.2
#55
08 CaymanS, PSS9, 19" R888, full weight
11/19/10 ACS Roval CCW, 1:59.413
12/19/10 Buttonwillow 13 CW, heavy rain, 2:43.704
09 Nissan GTR, JRZ CS, 20" R888, full weight
10/23/10 Buttonwillow 13 CW, 1:59.702
11/21/10 ACS Roval CCW, light rain, 1:52.164
11/06/10 SOW w. B&B, CW, 1:23.591
09/xx/10 SOW (CCW 1.8), 1:26.572
10/10/10 WSIR, CW, 1:33.611
#56
BW #13 CW: 1:45.5 - Yokohama Slick - 2009
http://videos.streetfire.net/video/F...9-1_685908.htm
BW #13 CW: 1:45.247 - Yokohama A048 (265/265) - 2009
http://videos.streetfire.net/video/F...-09_721061.htm
www.facebook.com/gofxmd
www.BillyJohnsonRacing.com
BW #13 CW: 1:41.949 - Hoosier A6 (275/335) - 2010 Super Lap Battle Finals -FXMD Turbo NSX
http://www.youtube.com/watch?v=l8ACPjGfGZo
billy
#57
a little ridiculous to be posting my times after billy johnson...
06 Cayman S, KW V3, NT01, full weight (heated seats rock when it's cold)
Autoclub Infield 1:17.6
SOW CCW (ridic hot, u guessed it, killed my ps system that day) 1:33.2
Big Willow 1:39.03
Last year was first year running in this car, hope to improve quite a bit this year.
Big Willow 1:39.03
#58
Big Willow 1:39.03
Big Willow 1:39.03
#59
I agree. I'm looking to get some bucket seats and a quaife differential sometime this year. That along with some more seat time should help tremendously. I'll post here as the year progresses. No plans for anything like headers, plenum or tune at this time due to budget constraints. Step at a time.
#60
I went out to the track for the first time ever, with my first Porsche ever (a recipe for disaster, right?). ha Anyway, did a best of 1:46.8 with my stock 2009 Boxster (no mods) and street tires at Big Willow. Is that decent?
