KA - In Memory of my Mom (Vincee) and best friend Michael J. Maring
#3092
Bill,
Yes, we are exploring dropping the turbo's from GT42R's to GT35R's and adding a supercharger with deverter valve. This would be in combination with the six barrel type throttle bodies.
The displacement is 4.316L. The stroke is 82.4 mm and the bore is 105.4 mm.
We already have the nitrous, however with the combination blowers, I doubt if we will be utilizing the nitrous. The motor was clearanced and pistons/lands and oilers were designed for nitrous or top fuel. The amount of torque that I am being told that will be available in the lower rpm's would make the nitrous all but useless useless.
#3094
You could avoid some of the above issues using only a single SC with the turbos but it will need to be fairly sizeable and getting the air to it and out of it via intercoolers etc is a real challenge in the 996 engine bay. It also gets even more complex if you want to by pass the SC when the turbos spool. You do not have to do this as there are plenty of set ups running in to the SC full time on other applications. You will need to match the turbos differently to if you are going to bypass the SC. Using TB's after the SC (if Positive Displacement type) need a serious by-pass system for when the throttles are snapped shut.
I think this is a a great way of filling in the power and torque curves left by big turbos and it has been proven in other vehicles. It is also very involved. I would be more than happy to share more details of what I have learnt along the way if it helps at all. Who is looking into this for you - Rob or Neil?
Good luck with whatever you end up deciding to do.
#3095
Porscha,
The design is Neil's baby.
Take a look at the sizing of the new motor compartment lid. Usually this space is used for extra large intercoolers. It is the second pic.
https://www.6speedonline.com/forums/2428924-post501.html
#3096
If someone is looking for a Techart II front end and a Porsche GT2 motor deck and spoiler in AS send me a PM. They are going to be sold. The rear is origional Porsche and the front is origional Techart. The front was the first Techart II sold in the US.
#3097
[QUOTE=cjv;2524173]If someone is looking for a Techart II front end and a Porsche GT2 motor deck and spoiler in AS send me a PM. They are going to be sold. The rear is origional Porsche and the front is origional Techart. The front was the first Techart II sold in the US.
You do realize that the guy on the right with the head closest to the sign is ME, right? I remember that day... I think it was in 2004 when I arranged that get-together at carlsen right?
#3098
Yep ......
#3099
These are some pics of past wide body conversions. These will be the same parts done in carbon kevlar.
Here is the wing withot the ducktails off the rear fenders. Also no defuser on lower part of the rear panel.
#3100
These are some pics of past wide body conversions. These will be the same parts done in carbon kevlar. The ones we are doing will be one inch wider. We will utilize 305's up front and 355's in the rear.
#3101
I'm not going to go over the suspension mods done to date, however I will briefly go over what will be added now.
A few years ago we purchased some experimental front race wheel assemblies. They were custom and used on the European race scene. Back then they were about 3K a wheel. I understand they are now about 7.5K per wheel assembly. ERP will be installing these parts on all wheels along with changing the front wheel cross bar to a lower GT3RSR cross bar.
In addition there will be some front lift bags to raise the front end above the normal half inch clearance for going up curbs. On 1badgt2's car they utilized hydralic operated bags. We will be using air operated ones.
That is going to be about it.
#3103
The above wide body pics are not of my car. I believe they may be of 1badgt2's car. ERP did some of the work on this car and these pics give somewhat of an idea as to where we are goin with ours. ERP is going to do the work on KA.
