KA - In Memory of my Mom (Vincee) and best friend Michael J. Maring
#1801
I just received the best Christmas present possible!
KA will be completed with the GT3 cams and alot sooner than I thought. A friend in another part of the world, who I have not only conversed with but also done business with, revealed the way to make it happen. I simply can't believe it.
I can't reveal details at this time, but if permission is given at a later date I will.
#1802
Isn't the variocam advance limited by the variocam sprockets? I don't understand why the pistons are hitting valves unless the turbo sprocket advances the cam more than the GT3 sprocket. Are you using a GT3 variocam sprocket?
Edit: I guess degreeing in a cam that doesn't have a keyway and isn't marked "correctly" could be a problem.
#1803
#1804
#1805
The GT3 cam does not utilize vario lift. the GT3 utilizes vario timing.
The pointer markers on the GT3 cam are located in a different position than those on the turbo cam. Finally the degree of advance utilized on the GT3 is different than utilized on the turbo.
I believe the timing advance is controlled by the codes in your ecu.
You simply won't believe the solution. All I can say is Porsche was advanced way beyond their time.
#1808
Originally posted by AMG ETR
So does that mean you don't need my help anymore??
Glad you worked it out, if you do ever need them again for some reason give me a shout!!
Evan
Evan
I attempted to get back to you yesterday after I received the information. I left two messages. I greatly appreciate your willingness to help.
What I spoke to you about yesterday is on hold until we test the solution given to us. After I found out about the solution, I had the part shipped out to S Car Go Racing by private jet. We now have our hands on it.
#1810
Originally posted by red944
Any updates?
Any updates?
So where do we go from here? We can use stock 996tt cams, a GT3 exhaust with a 996tt intake, use GT3 cams placing 996tt pointers on the cams (may have to modify as in tone down GT3 intake lift and duration) or find someone who already modified a turbo cam.
We hope to arrive at a decision in a few days.
#1813
Originally posted by sharkster
I just talked to Todd yesterday about their new cams... I think they're about to be put on the market...
A modified exhaust cam is not our problem. The problem is the intake cam. I don't believe they have anything on the intake. I don't know of anyone who has successfully modified the intake with a profile that allows a fast enough ramp down to prevent the piston from smacking the valve.
#1814
Originally posted by K24madness
Sharkster,
Have you installed your powerglide transmission yet?
Sharkster,
#1815
sharkster.
sharkster.
