KA - In Memory of my Mom (Vincee) and best friend Michael J. Maring
#1816
Originally posted by sharkster
Sorry I realized that after posting and reading more You're dealing with intake stuff... Man that does not sound like an easy fit or fix can be found
I believe we are on to a cam solution. I believe we have an answer. Probably a better way of putting it is we will find out when we fire her up and run her. Hopefully, with the timing, the intake valves will just miss the pistons on their down ramp.
#1818
Update .............
We have decided to utilize the turbo cams. The reason being with the base lift being left untouched passing smog will be a given. Now, we have sent the stock turbo cams and the GT3 cams to a cam manufacturer. They have profiled both cams giving us each cams lift, durantion, etc. We have told the cam maker the turbo's timing and instructed him to weld/grind the second set of lobes so we will make power to 8100 rpm's. This should take two to three weeks.
There is no guarantees. We still could smack an intake valve. However, if it works we will really have something.
#1819
Just starting to receive specs on these cams and a strange thought came over me. These cars have been around for about five years. Is there anyone out there (I'm sure there must be someone) who knows the profiles?
#1821
Originally posted by 03-turbo911
EVO have developed some new cams so they might have some information that might help.
Thanks for passing on the info.
Todd has been a big help to us. However, the cam he offers is an exhaust cam, the intake cam is where our difficulties exist. In addition, we have not accumulated enough information to determine weather the intake cam will actually be vario lift or not. Reason being will the vario lift be conducive with the higher rpm's we wish to utilize and will the non vario lift pass a smog test?
#1822
Chad- wouldn't it be worth it to give the Porsche tech people a call so that you can ask all of your crucial and important questions?
I would think they would know the answer to all of your questions because after all, they did design that car and engine!
#1823
#1824
Originally posted by cjv
Have you ever tried to get an answer out of Porsche or Porsche MS? It won't happen.
Honestly, have you ever tried to get ahold of any of them? I obviously don't have a reason to
I am sure, given what you are trying to acomplish, they would be more than glad to help you out!
#1827
We now have what we believe to be the cam shafts for KA. S Car Go Racing will start the mock up and pump the motor tomorrow. Then we will test to be sure the pistons and valves do not meet at full advance.
#1828
Chad, I don't know if you mentioned it already but I really don't feel like scrolling through 118 pages , what's the HP output that you'd be satisfied with when KA is done???
#1830
cjv, is there any reason why you couldnt have upgraded just pistons, bearings and rods with rod bolts... and then designed a custom single turbo setup with a matching fuel system to achieve your goal? it seems to me like you could have achieved your goals with a big enough turbo and a lot of boost. Do you honestly think the motor wouldnt hold up under moderate build up or is it more a case of you'd rather be safe than sorry?
