KA - In Memory of my Mom (Vincee) and best friend Michael J. Maring
#2327
Is dry sump oil possible on these motors? Just wondering why do a 8k oil pump over another option that would work. Space issues? Or is this option just simpler, and does the job just fine?(obviously cost isn't a concern on a project like this)
We used Swain on some exh. manifold coatings and exhaust housing coatings in the past. I think I may try the intercooler coating on my car, every little bit helps.
#2328
We will not have any oil starvation period. Why a 8K pump? It is extra insurance on a 200K motor.
#2329
Interesting. I haven't played with dry sump personally, but from what I understood of the concept, I thought the whole idea behind dry sump is to prevent the possibility of starvation. With the addition of an external reservoir(and pump?), it supplies a constant source of oil, and generally has a much larger capacity then normal/non dry sump engines.
I'm assuming the oiling system on these cars work a bit different then what I mentioned?
#2331
Swain lists on their price sheet at http://www.swaintech.com/store.asp?pid=10971
a cost of $125 - 225 for coating intercoolers with their BBE coating
#2333
While waiting for the motor installation we decided to do the fuel system. This will consist of:
1) New fuel rails.
2) New (larger) supply and return lines.
3) New external fuel pumps (900 pounds per hour capacity).
4) Fuel Cell.
5) Scavaging tank.
What is going to be done: We wanted a fuel cell so the car could be entered in the Nevada Silver Belt type events. We were not able to find any fuel cell companies who can supply fuel cells for the awd 996tt.The only company that we found who builds custom fuel cells is Vision Motorsports. Their custom built units are expensive. I had a good conversation with Vision's owner, Duane. He provided some very interesting and helpful information. I explained to Duane that we intended on removing the front axles, differencial and driveline. Duane explained to me that the 2005 Cup cars and the 996tt had the same front bulkhead and that the 2005 Cup's fuel cell would bolt in with very little modifications. Obviously information that would save alot of money. This says alot above Duane and Vision Motorsports. He could have sold us a custom fuel cell and instead forgone this sale by providing this information that he had (free of charge). I felt this needed to be mentioned. We need more people like Duane and Vision Motorsports. The added bonus is we will gain fuel capacity if we so chose to fill the tank.
1) New fuel rails.
4) Fuel Cell.
5) Scavaging tank.
#2336
Originally Posted by VRAlexander
I don't believe that 900lb/hr is enough for a forced induction engine of your caliber....you should re-calc. thouse figures and take into consideration the NOS....
#2339
Selecting the Proper Injector
In order to select the correct size injector for your application, you might wish to use one of the following formulas. In most cases a naturally aspirated engine will have a B.S.F.C of .50. This means that the engine will use .50 lbs. of fuel per hour for each horsepower it produces. Turbocharged engines will want to be at .60 lbs. per hour or higher.
Using these numbers as a guideline, you can select the approximate injector size in the following formula for a four cylinder, naturally aspirated engine at 200 bhp.
Most injectors will max out at 80% duty cycle and this is the accepted industry standard.
B.S.F.C is brake specific fuel consumption - How much fuel you are using per horsepower per hour
The proper injector for this application would be 31 lbs. / hr. or 330 cc / min To find the HP value of the of the above mentioned injectors use this formula
__________________________________________________ _________
To convert cc / min to lbs. / hr. - Divide by 10.5
To convert lbs. / hr to gal. / hr - Divide by 6
__________________________________________________ __________
To convert cc / min to gal. / hr. - Multiply by .015873
#2340
To find the new FUEL FLOW rate after a fuel pressure change:
Example 1:
If a 240 CC injector tested at 43.5 PSI is run at 50 PSI. The result would be:
Example 2:
The horsepower value of this injector would increase by the same rate
(X 1.0721), if all other engine management systems remain unchanged. Flow rate at old pressure
240 cc/Min divided by 10.5 = 22.86 Lb/Hr Flow rate at new pressure
257 cc/Min divided by 10.5 = 24.48 Lb/Hr
240 cc/Min X 1.0721 = 257 cc/Min 22.86 Lb/Hr X 1.0721 = 24.51 Lb/Hr 36.58 Hp X 1.0721 = 39.22 Hp
