Tuning/Modifications
KA - In Memory of my Mom (Vincee) and best friend Michael J. Maring
Rating: Thread Rating: 90 votes, 4.16 average.
  #2791
Old 11-02-2008, 05:54 PM
cjv's Avatar
cjv
cjv is offline
Moderator
Custom 996tt Intake and Exhaust Cams
Anyone know what lift and duration they are using?
  #2792
Old 11-02-2008, 07:07 PM
robmd99's Avatar
robmd99 has a reputation beyond reputerobmd99 has a reputation beyond reputerobmd99 has a reputation beyond reputerobmd99 has a reputation beyond reputerobmd99 has a reputation beyond reputerobmd99 has a reputation beyond reputerobmd99 has a reputation beyond reputerobmd99 has a reputation beyond reputerobmd99 has a reputation beyond reputerobmd99 has a reputation beyond reputerobmd99 has a reputation beyond repute
It depends on which heads you are using...stock vs mekinze
Robert
  #2793
Old 11-02-2008, 08:47 PM
joetwint's Avatar
joetwint Is a GOD !joetwint Is a GOD !joetwint Is a GOD !joetwint Is a GOD !joetwint Is a GOD !joetwint Is a GOD !joetwint Is a GOD !joetwint Is a GOD !joetwint Is a GOD !joetwint Is a GOD !joetwint Is a GOD !
Variocam or not?
  #2794
Old 11-03-2008, 10:07 AM
x50plt's Avatar
x50plt is a splendid one to beholdx50plt is a splendid one to beholdx50plt is a splendid one to beholdx50plt is a splendid one to beholdx50plt is a splendid one to beholdx50plt is a splendid one to beholdx50plt is a splendid one to behold
Cams
there is some info on Scotts Proto build posts, but this kind of info the builders normally don't share.
  #2795
Old 11-03-2008, 10:11 AM
996TT_STEVO's Avatar
996TT_STEVO has a reputation beyond repute996TT_STEVO has a reputation beyond repute996TT_STEVO has a reputation beyond repute996TT_STEVO has a reputation beyond repute996TT_STEVO has a reputation beyond repute996TT_STEVO has a reputation beyond repute996TT_STEVO has a reputation beyond repute996TT_STEVO has a reputation beyond repute996TT_STEVO has a reputation beyond repute996TT_STEVO has a reputation beyond repute996TT_STEVO has a reputation beyond repute
I use GT3 exhaust cams only... some think it doesn't make any difference... I totally disagree and think there is a difference and is a worthwhile mod if your in and about that area.
  #2796
Old 11-03-2008, 08:00 PM
robmd99's Avatar
Todd K has the ability to do what ever you want with the cams... the lobe is limited to your heads and the varicam has a magical touch... I love what his intake and exhausts cams do and sound for my car...
  #2797
Old 11-04-2008, 12:08 PM
WOODTSTER's Avatar
Rob,
O.T. How much power do you think your car makes today?
MK
  #2798
Old 11-04-2008, 02:59 PM
cjv's Avatar
cjv
cjv is offline
Moderator
I wanted to know if anyone knew what lifts and durations they were using with their particular set up. I understand the GT3 cam housings allow for higher lifts. I also know the maximum lift the 996tt and different GT3 housings will accomodate. I believe most people understand why a GT3 intake cam will not work in a 996tt. The cam housings are really the limiting factor ...... not the heads. I understand how durations between turbo and NA motors should differ. I had designed both my intake and exhaust turbo cams and tappets, non variable lobes, for GT3 housings and had them built from billets. I realize that all this and $2.00 will buy me a cup of coffee.
I really wanted to know if people were running anything other than stock turbo or stock GT3 cam specs. If so, did they know the lift and duration being utilized? As cams go on a turbo motor, bigger or longer doesn't mean better. I was looking for something other than factory specs to compare as I have the factory specs.
I know divexxtreme has used a custom weld/grind on turbo sticks and have shared cams specs with Knighten a long time ago. Is there anyone else out there?
  #2799
Old 11-04-2008, 03:23 PM
cjv's Avatar
cjv
cjv is offline
Moderator
Originally Posted by Phoenix
Third!
Hey, I have not even seen the car in over two years.
  #2800
Old 11-04-2008, 06:35 PM
WOODTSTER's Avatar
Joe,
spill the beans...
  #2801
Old 11-04-2008, 08:45 PM
joetwint's Avatar
3.8l,GT3 heads and valves machined to accept turbo cam housings and still using variocam.The cams are rewelded/ground turbo cams.Unfortunately I do not have the cam specs(Evoms proprietary).
  #2802
Old 11-04-2008, 08:48 PM
robmd99's Avatar
Joe
Congrats on your car... I cant wait to see it in person.
Robert
  #2803
Old 11-05-2008, 06:34 AM
WOODTSTER's Avatar
Talking
JOE and ROB,
Dyno numbers please....
  #2804
Old 11-05-2008, 06:35 AM
WOODTSTER's Avatar
CJV,
You need to find out some 9FF specs (although probably impossible).
good luck!
  #2805
Old 11-05-2008, 04:42 PM
joetwint's Avatar
Originally Posted by WOODTSTER
JOE and ROB,
800AWHP
You have already rated this thread Rating: Thread Rating: 90 votes, 4.16 average.
Quick Reply: KA - In Memory of my Mom (Vincee) and best friend Michael J. Maring
