KA - In Memory of my Mom (Vincee) and best friend Michael J. Maring
#3151
The no MAF was a bonus. I was looking to take control of the BMW RSR ABS. When I found out this system could also take control of the PSM I was shocked. It can also control my 6 barrel TB's and the drive by wire. Remember, we are not retaining, we are taking control with adjustments.
#3152
You must remember, we are using approx. .550 inch lift cams with GT3 pointers on these billets. This system will handle this too.
#3153
I said I was excited.
#3155
That should make things a bit more fun Anxious to hear further results, looks like your hitting the final stretch your epic buildup.
#3156
I promise to release all information very soon. It will be on the engine dyno in about 30 days. Then into the chassis. At that time I will report the good, the bad and the ugly.
#3159
#3160
PS. Inspiring project you have going on here.
#3163
It is the "BMW" RSR ABS. Bosch also makes a good one, however from the information I received ............. not as good. The BMW system stops far quicker with no "pump back" at the top of the pedal when hard braking.
#3165
Somethingthing like this http://www.bayareamotorsport.com/alphan.html The basic principle I mean. To control ABS & PSM you need slightly advanced thechnology than the one meant for e30 Beemers...
