KA - In Memory of my Mom (Vincee) and best friend Michael J. Maring
#3527
Robert,
Motor wise, especially response it is right up there. Currently, outside of that there a more than a few out there that we are playing catch up with. Have you seen 1badgt2's set up? The wide body adds some weight, but what is the trade off? Fifty pounds can make a real difference on the track, with that being said, look at the weight of Tom Kerr's car.
I said earlier that Cary was going to be doing additional work to the suspension. I believe some of the upgrades are the same as the ones utilized on 1badgt2's car. The front hub set up has been bought over four years ago and has been sitting at Cary's shop. I've never seen them but I believe they are the same ones used on 1badgt2's. If Cary is viewing he can confirm or deny and if different maybe post up a pic.
#3530
Compare the three holes with the three index's of the GT1 oil pump. You now can see where these cases really derived from.
#3532
Here is what they look like on the inside.
#3536
[QUOTE=cjv;2861738]This is a pic of the KW hydraulic lifts we intend to install on KA with the JRZ four way adj. that we currently have installed.
Those look a lot like the TechArt Hydrualic system I use on my RS. Very useful and nice to have
http://www.youtube.com/watch?v=i4h2mFRcGZI
#3537
I don't know if Techart makes their own or gets them from someone else. These are made in Germany by KW. We are using the lifts on all four wheels. In the down position there is 1-1/4" clearance under all the car.
Wait until you see the "on the fly" JRZ and sway bar adjusters.
#3539
Not sure as the car was delivered new with a modified suspension. The car sits fairly flat the the front slightly higher and this is with a lowered RSR front cross section.
#3540
Mexico? no not Mexico, you mean Los Angeles.
