Tuning/Modifications
KA - In Memory of my Mom (Vincee) and best friend Michael J. Maring
Rating: Thread Rating: 90 votes, 4.16 average.
  #3556
Old 07-07-2010, 11:51 AM
germeezy1's Avatar
germeezy1 Is a GOD !germeezy1 Is a GOD !germeezy1 Is a GOD !germeezy1 Is a GOD !germeezy1 Is a GOD !germeezy1 Is a GOD !germeezy1 Is a GOD !germeezy1 Is a GOD !germeezy1 Is a GOD !germeezy1 Is a GOD !germeezy1 Is a GOD !
Will this car ever be driven on pump gas?
  #3557
Old 07-07-2010, 03:24 PM
Sonny's Avatar
Sonny has much to be proud ofSonny has much to be proud ofSonny has much to be proud ofSonny has much to be proud ofSonny has much to be proud ofSonny has much to be proud ofSonny has much to be proud ofSonny has much to be proud ofSonny has much to be proud of
If the engine management is Motec, then Shane will be one., Motronics, Knighton., Link, bring someone from New Zeland.,cheers.
Originally Posted by onelove
The first and only name that comes to mind for this in mind mind is Shane Tecklenburg.
  #3558
Old 07-07-2010, 04:09 PM
cjv's Avatar
cjv
cjv is offline
Moderator
I don't believe so.
  #3559
Old 07-07-2010, 04:12 PM
cjv's Avatar
cjv
cjv is offline
Moderator
Neil Harvey of Performance Developments has the Link side covered. Todd Knighten will be working together with Neil. Need someone with turbo/nitrous experience for tuning the nitrous.
  #3560
Old 07-07-2010, 04:34 PM
germeezy1's Avatar
Originally Posted by cjv
I don't believe so.
Hmm that makes the numbers harder to guess.
  #3561
Old 07-07-2010, 04:43 PM
cjv's Avatar
cjv
cjv is offline
Moderator
The fuel that will be used is 120 octane, not to mention the head temperatures are close to 800 degrees lower than other 996tt motors due to ceramic coated combustion chambers, exhaust ports, valves, piston domes along with dual monster liner oilers and oil res under cylinder domes feed through rifle drilled rods/wrist pins ...... yes we will have some radical timing to play with. The Pulsed CD system is designed to spark with the ethanol fuel all the way down the liners to just prior to BDC.
  #3562
Old 07-07-2010, 04:50 PM
germeezy1's Avatar
I give up on guessing the power level, If I remember right I asked you if you were going to be running E98 which is 120 octane. I think you said you were using a different kind of fuel than that?
  #3563
Old 07-07-2010, 04:55 PM
cjv's Avatar
cjv
cjv is offline
Moderator
The only thing on top of the E98 is the 250 shot of progressive nitrous.
  #3564
Old 07-07-2010, 05:04 PM
germeezy1's Avatar
Oh maybe I asked if you were using E85 and you then told me E98.
  #3565
Old 07-09-2010, 02:28 PM
JDSStudios's Avatar
JDSStudios is a glorious beacon of lightJDSStudios is a glorious beacon of lightJDSStudios is a glorious beacon of lightJDSStudios is a glorious beacon of lightJDSStudios is a glorious beacon of lightJDSStudios is a glorious beacon of light
We believe we solved the worry about the Porsche case coming apart after a certain power level. That little detour took us five months out of our way.
Chad, besides HD rods, what else was done to prevent the case from falling apart?
  #3566
Old 07-09-2010, 05:53 PM
cjv's Avatar
cjv
cjv is offline
Moderator
OK ....... another source out of the bag. This company makes a lot stronger parts (including cases) to take these motors up to 5.0 liters. Liners up to 112 mm and cranks up to 84.0 mm. The cases are a bit different (dimension/design wise) ....... much stronger. The name of the company is Koro. They are in Germany. Their website in currently under construction. www.koro.de
One of the biggest issues with these monster motors is your piston speed or piston to rod ratio. Your really don't want it much under 1.6. The stock Porsche is about 1.64. The only way to keep it up there is to lengthen the rods. A stock rod is about 126 mm. It is almost impossible to make them any longer than 130 mm with a stock deck height and once you raise the deck height you open a whole new can of worms with things like timing chain length. etc.
  #3567
Old 07-22-2010, 06:02 PM
cjv's Avatar
cjv
cjv is offline
Moderator
I spoke today with Neil @ Performance Developments, the motor is just about finished. It looks like about two more days.
  #3568
Old 07-25-2010, 11:22 AM
FrodeFE's Avatar
FrodeFE is a splendid one to beholdFrodeFE is a splendid one to beholdFrodeFE is a splendid one to beholdFrodeFE is a splendid one to beholdFrodeFE is a splendid one to beholdFrodeFE is a splendid one to beholdFrodeFE is a splendid one to behold
And we are all looking forward to reading about it.
It has been a long wait, but I feel that reading/seeing some videos of the end result will be a grand finale
  #3569
Old 07-25-2010, 07:37 PM
cjv's Avatar
cjv
cjv is offline
Moderator
We had explored E85, however @ 104 octane the boost would be limited to well below our designed 2.8 bar. The good thing is we can pass the smog sniff test along with operate at lower boost levels with E85. We then considered E95, however availability is all but non existent in our area of operation. We have discovered E85 with an Aquamist injecting system with a certain mixture will provide a fuel with a 124 octane rating.
This is what we will be using for our engine dyno tuning.
  #3570
Old 07-28-2010, 09:21 PM
KhanNSX's Avatar
KhanNSX has much to be proud ofKhanNSX has much to be proud ofKhanNSX has much to be proud ofKhanNSX has much to be proud ofKhanNSX has much to be proud ofKhanNSX has much to be proud ofKhanNSX has much to be proud ofKhanNSX has much to be proud ofKhanNSX has much to be proud ofKhanNSX has much to be proud of
The only way we can source E98 locally is by buying it by the barrel.
Let us know when the motor lives.
You have already rated this thread Rating: Thread Rating: 90 votes, 4.16 average.
Quick Reply: KA - In Memory of my Mom (Vincee) and best friend Michael J. Maring
