My 2007 GTI 4-Door
My 2007 GTI 4-Door
Finally decided to sign on after stalking for so long...
Front end was recently shaved and suspension is FK Silverline x's. The current setting is geared for subframe suicide.
Cheers
Cheers
Thanks,
Those are probably not far off as these are 17x8.5 reproductions (IIRC no OEM wheels exists in that size) and they 9.5's at that offset would not work.
It's not uncommon for VW drivers to slip on wheels from a different make. You usually see the Corvette sawblades more often, other common wheels are from a Mercedes, Lamborghini, Bentley, Maybach etc. that are all 5x112 naturally and then Porsche wheels with adapters from 5x130.
These current wheels are on their way out most likely.
WheelB
07-06-2018 10:16 AM
ModBargains.com
996 Turbo Vendor Classifieds
10-01-2015 11:48 AM
