VW Touareg, Phaeton, R32 and other VolksWagen's
APR K04 Turbo Kit Release - TSI MK6 & MK5 GTI and Jetta
Old 12-22-2010 | 03:23 PM
GMP Performance's Avatar
Site Sponsor
One of the greatest benefits to the APR K04 turbocharger system is its simple, yet elegant design. APR's CNC machined direct compressor recirculation port on the OEM compressor cover significantly reduces engine bay clutter and saves the end user from the hidden costs of purchasing extra throttle body pipes, hoses, clamps and DV mounts for recirculating boost pressure. The compact design also removes extra charge piping volume to allow for lightning fast boost response and less locations for boost leaks. Furthermore, charge air pressure is directed directly at the compressor wheel which helps keep the turbo spooled upon lifting the throttle, minimizing turbo lag.
The OEM k04 turbocharger features a turbo muffler designed to reduce turbocharger sound in the cabin that also creates a restriction in the boost pressure delivery stream. APR removes the turbo muffler not only to enhance the sound of the turbocharger, but also to smooth the airflow across the previously baffled muffler section. A clean and simple CNC flange developed by APR's Engineering Team is bolted directly to the compressor cover in place of the OEM turbo muffler. A long mounting surface provides an excellent slip proof surface for mounting the silicon discharge hose and an o-ring between the flanges ensures a life of leak proof operation.
The K04 turbocharger was originally designed for an FSI engine, and as such, some items not required for the new TSI engine are present. The compressor cover features a port used in the FSI's PCV system, however on the TSI, this same port is located higher up on the intake tubing. APR has provided a gasket sealed laser cut port cover to block off this part and ensure no unmetered air leaks into the system. The design is clean and simple and never requires maintenance..
Optional OEM Exhaust Compatibility
While an APR RSC Performance Exhaust System and APR high flow exhaust software is recommended for maximum power, if you're in a situation where running a high flow exhaust is not permissible APR has developed software specifically for use with your OEM exhaust system. You may switch between high flow exhaust software and OEM exhaust software free of charge at any time.
APR's Patented EMCS Technology
Featuring APR's Patented EMCS program switching functionality and DirectPort Programming, APR's Engine Management Calibration for this conversion package allows for a range of Octane and situation specific calibrations to be installed simultaneously on your vehicle's ECU. These programs and features are able to be cycled through via your existing factory cruise control and activated in less than 20 seconds. You will be able to choose 1 to 4 Programs listed below. You will also be able to add APR Security Lockout, APR Fault Code Erase and APR Anti-Theft features.
Kits Instock @ GMP Performance
PM or Email for Pricing and Installation Quote
MKrisel@gmpperformance.com
Last edited by GT3 Chuck; 12-22-2010 at 04:14 PM. Reason: no pricing in open forum
BlackMarketRacing
12-08-2015 01:49 PM
ECS Tuning - VW
08-19-2015 02:15 PM
ECS Tuning - VW
08-19-2015 10:43 AM
ECS Tuning - VW
08-19-2015 08:58 AM
ECS Tuning - VW
08-18-2015 01:04 PM
Quick Reply: APR K04 Turbo Kit Release - TSI MK6 & MK5 GTI and Jetta
