295 Tires on 11.5" Wide Wheels
they will go on 11.5 i think easily but not for track work - you will ride on the shoulder under hard driving.
i tried, for interest, to see what it would look like on a 12" and whilst it fits, it looks silly and the rim is far too big.
the tyre itself will have an influence.
slaaw,
i saw this thread on the for sale section...he has 285/30/19 on 11.5
https://www.6speedonline.com/forums/...d.php?t=100591
check it out or contact the guy for the fitment and the ride
Ahmad
Ahmad
In Japan its not uncommon to stretch narrower tires onto wider wheels. Ive seen a few Lexus and Infiniti's done like that before. If you want something more performance, go with a narrower wheel or wider tire.
I have done it, long story, it works and I have not had any issues. 305's or 315's fit much better. The tires looked stretched, more of \ angle than normal when looking the tire sidewall. I recently did a run on some tight twisties, hard enough to break the tire traction in the corners, and the tire held up fine. I would say the run was about 30 miles of hard driving (back tracked the same road several times) I have PS2's on the the wheels.
Realistically you should be going with at least a 305. Tire width varies manufacture to manufacture.
I personally wouldn't do it, and it's definately going to look stretched. If you can fit a 305 that's what I'd shoot for. You look to be at stock height in your avatar, but I don't know exactly how much room you have to play with.
COBB Tuning
11-09-2015 09:02 PM
oufan2929
11-08-2015 09:26 PM
Sterlingc1975
08-22-2015 03:30 PM
