HRE Monoblok 43 Design
#31
You statement is not effective as I do not know the wheels will fit correctly and that's why I ask the offsets. I know what the OEM are and they are way off from what I want.
#34
why dont you tell me what you want and I will see what I can do. If we feel it is safe and correct for the car we may be able to do it for you. I can tell you as a company we have built 3 piece 12" wide for the rear of a 360, but feel it is aggressive.
Never hurts to ask though. Let me know and I will go to work.
#35
The 325 is a dead-on replacement for the 275/40-18. It's also same tire used on the GT2.
With the correct rear offset of 50-52 mm it sits perfectly where it should w/o being tucked under the rear fender lip.
So 11.5"-12" is an ideal width according to Michelin. I believe it's TechArt that uses 11.5 on their Porsches.
#39
So it does not surprise me and I appreciate the efforts.
#41
I like the 11" rear because the car really doesn't have the room in the front to put a huge tire to balance things out (if you have a huge rear tire). We have done 12's before, and although they look awesome, they introduce a pretty good deal of understeer into a car that has a slight understeering bias from the factory. We try to be a tiny bit conservative with our monoblok line too, but have the capability to get to pretty much any reasonable offset that the customer is looking for.
#44
That's my situation but it's curable!
The third wheel down, that's the P40? It only is available in 11" widths for the 360?
What is its offset for the 360 please, Marc?
#45
the p40's are an awesome choice. thats what i have on my car
