Wheels/Tires
HRE Monoblok 43 Design
Old 08-29-2008 | 04:58 PM
DynamicMotoring's Avatar
DynamicMotoring is infamous around these parts
Originally Posted by Gcalo
I don't think this makes sense. They would have to add material in the hub to achieve a more positive offset; subtract material to make a less positive offset.
Positive is out and away from the center line of the bearing; negative is in and away from the bearing centerline towards the vehicle's center line.
Correct?
Positive offset means the mounting face is toward the outside of the wheel(past the centerline of the wheel) and lower offset means the mounting face is toward the backside of the wheel. If you machine down the mounting face, it becomes closer to the "street side" of the wheel making it a higher offset.
  #62
Old 08-29-2008 | 05:03 PM
Tech1_Mike's Avatar
Tech1_Mike has a reputation beyond reputeTech1_Mike has a reputation beyond reputeTech1_Mike has a reputation beyond reputeTech1_Mike has a reputation beyond reputeTech1_Mike has a reputation beyond reputeTech1_Mike has a reputation beyond reputeTech1_Mike has a reputation beyond reputeTech1_Mike has a reputation beyond reputeTech1_Mike has a reputation beyond reputeTech1_Mike has a reputation beyond reputeTech1_Mike has a reputation beyond repute
Correct?
No. Adding material to a back pad pushes the wheel outward from the centerline of the vehicle, making the offset more negative. Removing material tucks the wheel further under the vehicle, making the offset more positive.
HRE Monoblok wheels are not exactly lightweight. The P40 in 19x8.5 weighs 21.6 lbs. The 19x11 weighs about 24.9 lbs.
  #63
Old 08-29-2008 | 05:05 PM
Gcalo's Avatar
Gcalo is a jewel in the roughGcalo is a jewel in the roughGcalo is a jewel in the rough
Originally Posted by DynamicMotoring
--- If you machine down the mounting face, it becomes closer to the "street side" of the wheel making it a higher offset.
Contradicts what you said.
If you reduce material from the mounting face of the wheel it brings the wheel "in" closer to the the centerline of the car. That's a negative offset.
  #64
Old 08-29-2008 | 05:09 PM
WheelEnhancement's Avatar
WheelEnhancement has a brilliant futureWheelEnhancement has a brilliant futureWheelEnhancement has a brilliant futureWheelEnhancement has a brilliant futureWheelEnhancement has a brilliant futureWheelEnhancement has a brilliant futureWheelEnhancement has a brilliant futureWheelEnhancement has a brilliant futureWheelEnhancement has a brilliant futureWheelEnhancement has a brilliant futureWheelEnhancement has a brilliant future
The same size HRE wheels are 2.4 pounds lighter each front and 4.5 pounds lighter each rear than factory Porsche 997 Turbo forged wheels manufactured by Fuchs. In my opinion the HRE P series wheels are considered lightweight.
  #65
Old 08-29-2008 | 05:11 PM
If you remove material from the back pad of a wheel you increase the distance from the centerline to the backpad.
  #66
Old 08-29-2008 | 05:20 PM
Offset just means where the mounting face is in relation to the centerline of the wheel(not in relation to the car). If the offset is neutral, the mounting face is in line with the center of the wheel. If the mounting face is closer to the back of the wheel (in relation to the centerline) that means you have a negative offset.
I hope that explains it better.
  #67
Old 08-29-2008 | 05:21 PM
Tech1_Mike's Avatar
IMO, at under 20 lbs for the front wheel, the Champion and Dymag wheels better deserve the moniker.
  #68
Old 08-29-2008 | 05:26 PM
HRE monobloc wheel weights are within 1 pound to Champion wheels that have similar design features, in this case flat face, or no lip. The Dymag wheels you mention are nearly twice the $.
  #69
Old 08-29-2008 | 05:32 PM
Tech1_Mike's Avatar
You win.
  #70
Old 08-29-2008 | 05:36 PM
Gcalo's Avatar
Is this not correct?
Offsets:
There are three basic offsets, Negative offset, positive offset, and zero offset. Negative offset is the when the mounting surface is closer to the center of the car compared to the wheel centerline. Positive offset is the opposite, and refers to when the mounting surface of the wheel is farther away from the car than the wheel's centerline. Zero offset refers to a wheel that is neither positive or negative offset. The mounting surface is centered in the wheel.
  #71
Old 08-29-2008 | 05:38 PM
Offsets:
No this is not correct. The positive offset and negative offset description and images are reversed.
  #72
Old 08-29-2008 | 05:42 PM
Gcalo's Avatar
Would you please look at this from the Tire Rack and tell me if it then coincides with what I above published?
http://www.tirerack.com/wheels/tech/...jsp?techid=101
  #73
Old 08-29-2008 | 05:46 PM
The description and image from Tire Rack are correct. I may be better able to explain this on the phone. Please call.
  #74
Old 08-29-2008 | 05:50 PM
After reading your description and reconsidering your drawings I would agree that your drawings and description are correct.
  #75
Old 08-29-2008 | 09:45 PM
Gcalo's Avatar
That is a big help for me, and I apprecaite you confirming this.
So then as to my original proposition, if a wheel maker removes material from the back of the wheel, it moves in a negative direction=negative offset.
So to get a positive offset two things would have to occur:
a) the rear forging would have to be quite deep (thick) to be machine removed to the desired offset
b) or material would have to be added such as in a spacer.
Thus, the wheel would have to be forged to have enough material to allow its offset to be changed by machining.
Quick Reply: HRE Monoblok 43 Design
