Wheels/Tires
Spacers and locking lug bolts
Old 05-08-2008 | 08:18 PM
ClayMan's Avatar
ClayMan has a spectacular aura aboutClayMan has a spectacular aura about
I will be using H&R 15mm spacers front and back, which require 60mm bolts. I'm having trouble finding locking extended lug bolts to go with them. Will it be OK to use 4 proper extended lug bolts with 1 regular locking bolt on each wheel? What's the standard practice for locking wheels with spacers?
Old 05-08-2008 | 10:50 PM
call-911's Avatar
call-911 is infamous around these parts
Wouldn't recommend using the shorter locking bolt. If you can't find a longer locking bolt, try using a threaded stud of proper length and then you can use a locking lug nut.
Old 05-09-2008 | 12:00 PM
damon@tirerack's Avatar
Moderator
If someone wants your wheels, they are going to get them. Consider your safety first.
damon@tirerack.com
877-522-8473 ext. 4643
574-287-2345 ext. 4643
Or use this link:
Old 05-12-2008 | 09:35 AM
Don Nguyen's Avatar
Don Nguyen is infamous around these parts
Exactly, run the correct length bolts. You don't want to crash your car because of it, or end up breaking something else.
NIKAS
08-20-2019 07:53 PM
shifter_
09-08-2015 12:07 PM
WheelB
991 Turbo Vendor Classifieds
09-03-2015 10:26 AM
manfred@loma_wheels
09-02-2015 11:22 AM
Quick Reply: Spacers and locking lug bolts
